Results 1 to 7 of 7
    Senior Member Two Rings Aphex350's Avatar
    Feb 11 2008
    World, U
    Exclamation Engine was smoking earlier
    Earlier today I did a nice little run with a bike (couldn't make out what bike it was). I pulled by a few cars and the guy gave me the . Anyway, I started to smell what turned out to be burning oil. When I parked, I opened the hood to find smoke coming from what looked like under the MAF, or just around that general area and when I opened the oil cap, a little smoke came out of there as well. Also, there are no coolant leaks AFAIK.The smoke went away after a while and everything was fine after. I did notice a few drippings of oil on the pavement after I moved the car. This is the first time that this has happened. From what I've searched and read so far it seems like my valve cover gaskets may need replacing, but I am not sure. This may be no factor whatsoever but today was one of the most humid days around my area in a while. Engine is stock except for AWE rsk04 kit, diverter valves, intercooler, piggies and twin2. Any advice will be greatly appreciated!
    Forgot to mention that it didn't look like it burned too much oil
    2000 Santorin S4
    AWE Stage 3+
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    Re: Engine was smoking earlier
    lol at stock except stage 3 kit hahah anywho idk man it could be a number of things bro ... try to get n oil dye and use a uv light to find the leak if there is one.... also hope its not your k04s like me :(
    cheers
    --daniel
    Apr 05 2007
    99% certain it's your valve cover gaskets and/or cam chain tensioner gaskets. Just do this complete kit and you're done: http://www.blauparts.com/proddetail.asp?prod=GF21002
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    2nd the valve cover gaskets, mine smoked after every hard run until I broke down and did them
    I don't think I care anymore
    Jun 14 2007
    2000 S4
    Connecticut
    haha second on, im stock except for awe rs4k04 kit.... makes it sound as if its something you can buy on the dollar menu @ mcdonalds :)
    Feb 11 2008
    World, U
    I'll order the kit, thanks. It can be fun to downsize the S4 to help give passengers a more unexpecting surprise when they get a ride
    2000 Santorin S4
    AWE Stage 3+
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Don't forget the side order of intercoolers and a full exhaust. I'll be taking that to go please.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
