Results 1 to 23 of 23
Thread: Finally done!
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Finally done!
    A little pissed! Started to install my RS4 rear sway around 11:30 this morning and didn't finish till NOW! Word of advice....get some vice grips for the metal brackets that are going on the RS4 bushings. The metal brackets don't fit very well and the vice grips help get the bolts get closer to the holes they mount onto. Glad it's over!
    A few pics.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: Finally done!
    so, how does it feel?
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Finally done!
    Quote Originally Posted by widgget View Post
    Well...I haven't taken it out yet. Prob a little later. Hungry, haven't eaten dinner yet.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Marin, Ca
    Re: Finally done!
    I think I spy a kayak... or a surfboard. Have fun with those corners.
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Dec 06 2007
    Re: Finally done!
    nice please give a review later, and boy is ur exhaust rusted lol!
    Is it just me or is there a new trend going on with everyone having there feet in the picture??
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Re: Finally done!
    Quote Originally Posted by XCARTELX View Post
    kayak
    4 DIY
    FlexTuning
    Amulet 1.8TM
    BAT#46
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Finally done!
    Quote Originally Posted by AudiA4Turbo22 View Post
    Yea, exhaust is next!!! Dunno if I am going to do it myself considering how long it took me to do the bar. Seems when I do self install it never goes according to plan.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Re: Finally done!
    Quote Originally Posted by Firefighter637 View Post
    haha, man u have no idea...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Re: Finally done!
    Man, I had some trouble with this install, but 5 hours?? It really helps to have two people working on this one. One person holds the bracket down as hard as they possibly can while the other attempts to tighten the bolts. That's how I did it at least.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Active Member Two Rings JVK's Avatar
    Apr 15 2008
    Portland
    Re: Finally done!
    You should have read the previous RS4 update thread, everyone gave their input on tips to make it easier. I will agree and say Vise Grips are the key to making this install go through with a breeze.
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Finally done!
    Quote Originally Posted by Dolphin18T View Post
    Yea, as I was laying under the ass of the car I thought to call my friend but I guess I have to much pride. 5 hours is WAY to long!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings redline_redline's Avatar
    Dec 18 2006
    Vienna, VA
    Re: Finally done!
    Here's another tip for getting the brackets to stay.
    RS4 Sway Install = Hammer Time!
    whack the shit outta the thing and it'll stay on there
    2012 Phantom Black S4 ~ RS4 Grille ~ 19x9.5 ET45 Gunmetal V710s w/ MPSS 255/35/19 ~ Magma Red Silk Nappa ~ Carbon Atlas Trim ~ Alu Optics
    Gone: 2002 Denim Pearl Blue A4 ~ GIAC FX-K03 Stage 1+ ~ Genesis 380cc ~ Retrofitted USP front with custom mesh grills ~ S4 Rear ~ ACE 18" Hyperblack RS4s ~ Custom Magnaflow w/14851s ~ Hyperboost Compact ~ BoostedTech ~ RS4 Rear Sway ~ FK Housings ~ LED tails ~ M3 Lip Spoiler ~ SPP Yellow Fogs ~ 20% Tint
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Finally done!
    bare feet FTW!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Finally done!
    Two people definitely helps. At least you accomplished what you set out to do, regardless of how long it took!
    I did it solo, with a vice grips and bare feet too. Took me maybe an hour. Helps to have the car's wheels on ramps so the suspension is settled.
    My write-up:
    RS4 rear sway bar install. No photos but I jacked the car up via the rear tow-hook. Then placed some wood under the tires and lowered the car so it was sitting at ride-height (don't have any ramps). I then removed the sway bar end link bolts (16mm socket). I then removed the sway bar bushing brackets (13mm socket and open-end). After about a minute of struggling to remove the sway bar I realized an easier way. Drop the two rear-most exhaust mounts and let the exhaust hang. OEM sport suspension sway bar out and RS4 in. Now the fun part. Getting the bushing clamps ontop of the RS4 bushings and sway. After some force I got the upper bolts in. I then used a pair of vice grips to clamp the lower end to the frame. I could then insert the lower bolt in and then drive both the upper and lower bolts in with the socket and wrench. Then I lowered the car down onto the blocks of wood (my makeshift ramps) and bolted up the end links. Job complete.
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Finally done!
    if you have a wrench you can get those inner links to hold it I think, at least thats what I remember
    - Clint
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Re: Finally done!
    Quote Originally Posted by redline_redline View Post
    The guy I had install it for me (because I learned my lesson to never attempt doing anything myself) had these really long screws that fit in so he used those because he couldn't get the brackets to catch with the short screws, then one by one took out the long ones and drilled the regular screws in. That seemed to work really well, but probably won't help most people unless you have a good amount of random hardware laying around.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Re: Finally done!
    it was tough, but not 5 hours tough for myself
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Veteran Member Three Rings Shak's Avatar
    A4 B6
    Northern VA
    Re: Finally done!
    Haha atleast you got it in there! That's what matters.
    I was too lazy to attempt it myself since a. I don't have the ramps to raise the car, and b. it would be a pain to do it alone. I paid the shop for 45minutes of their time so they charged me $60 to put it on. Good deal I thought but I mean I could do it for free and saved the money.. still.
    2002 A4 Quattro Tiptronic w/ Sport Package
    Mods:
    Cleared Corners; Headrest Mod; Symphony II+; Aero Wiper Arms and Blades; Painted Lowers; RS4 Rear Sway Bar, 35% Window Tint
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    Re: Finally done!
    That's how I installed everything on my car, isn't that normal?!?
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
    Dec 06 2007
    Re: Finally done!
    so Shak what do u think of the result??
    -Kirk
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Finally done!
    Yea, at certain times of the install I felt like doing that!!!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Dec 18 2006
    Vienna, VA
    Re: Finally done!
    no seriously to keep the brackets on if you hit them with the hammer they will stay around the bushing. That's what I did haha.
    Dec 18 2007
    nj
    Re: Finally done!
    "you hit them with the hammer"
    isn't that the answer to just about everyone of lifes problems?
