Results 1 to 25 of 25
Thread: Air Compressor
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Air Compressor
    Any suggestions on an air compressor? I'm just looking to fill up my tires every week or so. I've grown lazy and don't feel like going to get them filled somewhere.
    I was looking at something like this:
    http://www.amazon.com/gp/product/B00...pr_product_top
    I'm not sure how that will handle the high PSI of our wheels and there seem to be some reliability issues based on reviews.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Re: Air Compressor
    I want to get one of these guys:
    http://www.sears.com/shc/s/p_10153_12605_00915312000P
    Only $119 and you can get some versatility out of it. Every garage needs some type of air compressor.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Dec 05 2006
    So. Cal.
    Re: Air Compressor
    Yea, I'd probably opt for one from Sears. That way you can do other things in addition to filling up your tires.
    Sep 17 2006
    Houston, TX
    Re: Air Compressor
    That's not so bad. You'd hope Sears would support it a little better than the other brands.
    Also saw this one on Amazon:
    Jun 05 2007
    Phillips Ranch, CA
    Re: Air Compressor
    I have this one and all the attachments u will ever need. I got mine at Home Depot. It works great! I would get atleast a 6 gallon tank, plus with this compressor it works great for detailing your vehicle/s too after a wash.
    Veteran Member Three Rings caitovS4's Avatar
    Nov 19 2006
    Re: Air Compressor
    enigma1406 - I strongly recommend you don't buy either one of the units you referenced. Those actually are not even compressors, they are inflators.
    Yes, they're less expensive but the performance and all around versatility compared to an actual compressor is night and day.
    The unit JMG referenced from Sears is a good choice if cost and size are main considerations. This type of unit will be great at filling tires, inflatables, using air nailers and blow guns.
    Quality on the Sears' units are decent and suitable for home use.
    If you want to spend a bit more, Porter Cable has a 6 gallon pancake that is avaialble at most home centers and can be had for about $149-$169 with accessories.
    This will give you a slight increase in quality, performance and tank capacity.
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    Re: Air Compressor
    I have a Makita MAC700. Small, Oil lubricated, quiet and quick recovery.
    http://www.makita.com/menu.php?pg=pr...det&tag=MAC700
    B7 RS4 mugello
    B7 S4 moro
    Q5 meteor
    Sep 17 2006
    Houston, TX
    Re: Air Compressor
    Quote Originally Posted by caitovS4 View Post
    I'm starting to realize that. I'm just going to put in a little more money and get a nicer one. It can't hurt having something to use while cleaning the car as well. I guess that'll help with the laziness. Thanks for the advice and suggestions everyone.
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    Re: Air Compressor
    +1 thanks for the advice
    Oct 11 2007
    Suburbia
    Re: Air Compressor
    I have a great little one on wheels. I bought it with some air gun accesories from Harbor Frieght Tool Comp. for about 220$. I think its a 4 gallon capacity with a peak of 175 PSI. All quick release hoses and accesories. I use it to take tires on and off, dust off the interior and exterior/enginebay, fill tires and detail the paint. They are pretty great to have, theres an almost infinite amout of possibilities with one. Just make sure you get one with a PSI of at least 125 and a decent sized air tank, or air powered tools may not run right.... Good luck on your choice.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Air Compressor
    I have this one:
    It was a bit overkill, but looks bitchn in my garage. I'll also be able to do some painting and such with it if I need :)
    http://www.sears.com/shc/s/p_10153_1...+%26+Inflators
    Registered Member Two Rings Fleet Admiral's Avatar
    Mar 12 2009
    A6 2.7 | ecodes | CH air comp|
    MI | umich.edu
    Re: Air Compressor
    Quote Originally Posted by WinterRunner View Post
    I had a great big one of their 21 gal @ $144 for 1 day before finding out just how damn loud it was, an oil lube direct drive model(horrible buggers). Took it back and got a Campbell Hausfeld 20 gal belt drive for $300, nice & quiet.
    Quote Originally Posted by ieatfishburitos
    Ouch, judging by the low rantings. And for the price again, Campbell Hausfeld would be better and cheaper at tractor supply. Next best or 1st would be an Ingersoll Rand compressor, which is about the same price for 60gal. again at tractor. Usually IR is double the price, and heavier
    I looked through a crapload of models. Most 2nd hand ones were under the CH moniker, only different brand names = HUSKEE, KOBALT, MAXUS...
    You can't lose choosing me doll face. Every lotto ticket I scratch off is a winner, cuz I'M a winner
    Senior Member Three Rings ProfileX's Avatar
    Mar 12 2009
    S5 2011
    Denver, CO, USA
    Re: Air Compressor
    I bought the Porter-Cable Job Boss C3151 for $289 back in 2006, it's been reliable so far. It was really loud until I tightened the bolts and put some foam between the compressor and the handle.
    http://www.deltaportercable.com/Prod...roductID=11501
    http://www.amazon.com/Porter-Cable-C...HT5/ref=sr_1_1
    May 31 2009
    '11 S4 / '10 R8 V10
    Michigan
    Re: Air Compressor
    As others have said, a spending a little more will give you many more potential use options. If you think you may want to run air tools, 4cfm @ 90 psi and a 4 gallon tank are the bare minimum specs. Also, cheaper compressors are noisy and fragile. You also have to consider if you want an oil lubed unit or not. They are sturdier but you have to change the oil from time to time.
    I have the Makita MAC2400 and am happy with it. It runs my impact wrench fine, which is the most air hungry tool I have. Nailers will run on anything. It has a low rpm motor that is pretty quiet also. The similarly priced DeWalts are nice too. Last I looked those were the two brands to look at for a medium sized hot dog. I do sometimes have to wait for the compressor and will be looking for something a little larger next time. If you have room for a 60 or 80 gallon unit, go for it. I don't have room and need a portable unit, so these types will have to do.
    http://www.amazon.com/Makita-MAC2400...3993950&sr=1-3
    Jan 10 2007
    Earth
    Re: Air Compressor
    Quote Originally Posted by Fleet Admiral View Post
    I have nothing but good things to say about my compressor. Statistically are a few bad ratings on their webpage representative of the thousands of units they sell? Their target demographic probably doesn't even use the computer.
    Again, my compressor works great, I still feel good about the purchase 3 years later. I guess I should also point out that I purchased it for $450 or so, where as the link today shows $600+.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Established Member Two Rings mattdogg02's Avatar
    Nov 12 2007
    Lucas, TX
    Re: Air Compressor
    The most vocal are those who are unhappiest
    Mar 12 2009
    MI | umich.edu
    Re: Air Compressor
    Quote Originally Posted by SteveR View Post
    I'd say always go with oil lube*belt drive, for anything with power tools. The oil lube*direct drive motors are horrible and should be banned. The oil-less are even worse and are pretty much throw away items. But when one buys that $200 Husky 20 gal oil-less model, one wouldn't be expecting it would only last 1,000 hours or so before crapping out and throwing that $200 away.
    I saw that those run at around 1700 rpm, compared to the other oil lube direct drives that reach 3500 rpm, which makes the big difference and makes it as quiet as the belt drives that run between 800+ rpm. Right around 65-80 dbA. That oil lube I originally went with could drown out a KISS concert. Had to be over 120dBA
    Mar 12 2009
    MI | umich.edu
    Re: Air Compressor
    Quote Originally Posted by ieatfishburitos View Post
    Were you able to use it for spray painting? I noticed it only goes to 10cfm@90. Most recommend 13 or 15+ for that.
    Established Member Two Rings eweu's Avatar
    Aug 25 2008
    Silicon Valley, CA
    Re: Air Compressor
    Don't mess around. Get a good one and it will last for a long time. I have a Thomas. That's basically all they do is pumps and compressors. Their compressors are oil-free yet quieter than the oil compressors you'll find from other manufacturers. They also draw less power so you can easily run them off a 15 amp circuit, which many compressors can't deal with. Check it out.
    http://www.amazon.com/dp/B0000ANEIL/
    Mar 12 2009
    S5 2011
    Denver, CO, USA
    Re: Air Compressor
    Quote Originally Posted by eweu View Post
    Don't mess around.
    Wow! You're not kidding. $600 is a lot of money for a 4 gallon tank. I like how the product descriptions says "Often called The Cadillac of Portables".
    I had to convince myself to spend $300, I thought that was a lot. The OP said "I'm just looking to fill up my tires every week or so" which seems too often but assuming he did it every 2 weeks that would mean each fillup would cost $24 for the first year, or $12 over 2 years.
    Let's see if anyone can top $600 for 4 gallons/115psi!
    Aug 25 2008
    Silicon Valley, CA
    Re: Air Compressor
    Quote Originally Posted by ProfileX View Post
    Wow! You're not kidding. $600 is a steal for a top-of-the-line manufacturer. I like how the product descriptions says "Often called The Cadillac of Portables".
    FTFY
    The thing about air compressors is that most people just want something small for a specific task, and then once they have it they start seeing more uses for it. I've seen countless guys pick up a small compressor on the cheap. Then they later complain that it won't work with certain tools or that it's terribly loud. So they end up buying another compressor. By that time they have spent more than $600. Do it once. Do it right.
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: Air Compressor
    ideally you want something with a metal tank on it. The ones that you showed covered in plastic are slow and will most likely break much much sooner. you should opt for a minimum of 2-3 gallons if you dont plan on working on your own car. If you do, id go 6-10 gallon minimum
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Mar 12 2009
    MI | umich.edu
    Re: Air Compressor
    I just saw an Ingersoll Rand 4.5gal at tractor supply for $100, now that's more worth it, and about a 78dbA rating. THEY are truely the Audi of air compressors. It may be just short of the 5CFM at 4.4 to the other one, but it'll still hold its own for HIGH quality air tools like IR that use 4.3/4.0 CFM.
    Exactly, that's why you shouldn't go the small route. For the same price, minus some lost garage space, you can get a belt drive that can be upgraded and rebuilt in the future with higher CFM pump and higher HP motor.
    Mar 12 2009
    MI | umich.edu
    Re: Air Compressor
    Well I just found Eaton makes portable ones too, and have a stripped 8gal version for $180 on ebay, $100 more for the motor or find your own. Makes 10CFM. That's DOUBLE of most anything you'll get until you reach the 60gal tank pumps. Those are wicked stats.
    Heck you could run the impact gun on the pump alone without the air tank.
    Plus it's belt drive, oil lube, which is super quiet. Not even the makita can compete for longevity/power/quietness.
    http://www.eatoncompressor.com/catal...37/6523745.htm
    May 26 2009
    Tucson, AZ
    Re: Air Compressor
    I have a decent compressor from Home Depot that I've had for many years. It's never had issues but hasn't been used in a year and a half because I ended up with something much better and way more convenient....a Nitrogen tank. The tank with regulator was a little over 200 and if you are only using it for tires you will likely never need to refill it. I've used it for assorted power tools and an air brush and it works far better than any compressor would. I bought it originally to use for my shifter kart tires but now use it for everything. I haven't had to refill it yet and I've had it for almost a year now.
