Results 1 to 14 of 14
    Mar 21 2008
    AWE Pressure tester Kit
    i was on vacation and decided to splurge the 20$ and buy the AWE pressure tester kit. I thought that this kit would come already assembled but i guess not. the kit comes with all the shit i could have just bought from home depot.
    Now my quesiton is the whoile drilling a hole into the pvc pipeing and theading the air compressor attatchement peice into there. I dont see how in anyway that will thread in perfectly unless i thread the pvc hole to match?? ANy enlightenment please :|
    Apr 05 2007
    Re: AWE Pressure tester Kit
    Quote Originally Posted by looseboost View Post
    PVC is softer than metal. The threads should cut in as long as you make the diameter of the hole in the PVC small enough to get it started, but still let the threads cut in.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by exorcet View Post
    And if you're really anal, you can put some teflon thread tape on it too..
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    kinda sucks it didn't come assembled
    B5 S4 AWE Stage 3 - sold
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Rajan147 View Post
    From Awe's website:
    Small boost leaks in the intake can add up to major headaches for the 2.7T, especially with the addition of larger turbos and larger injectors.
    We devised a simple pressure tester to find the boost leaks that may be hindering your 2.7T's performance. It makes troubleshooting much easier, and has helped us maximize the performance of all of our customer's S4s and A6 2.7Ts.
    We have provided all the part numbers of this kit in an FAQ if you wish to source them on your own. Pressure testing the intake of the 2.7T engine is a must-do in order to eliminate the source of many basic problems.
    Please note that this kit requires assembly. Also note that a source of regulated compressed air is required to operate this tester. Please read the FAQ document if you have any questions on the operation of this tester.
    Nov 23 2007
    Columbus, OH
    Quote Originally Posted by mholme View Post
    From Awe's website:
    touche, although i wasn't disputing that, rather just making a comment
    Jan 29 2007
    08 S4 00 S4
    MD
    I know, I should've quoted the original poster..he apparently didn't realize this...
    Mar 21 2008
    Well apparently but we all make mistkaes and dont read fine print sometimes
    anyways i did it and it came out perfect deff not like plastic the pvc adjusts to the threads thx.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    you should of bought the one from VAST Performance , come all ready to use
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    so how do you get the air in the system once its hooked up? Do you just blow on the valve? I'm assuming it has one of thse stoppers like the floaties I put on my arms when i go to the beach?
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Yep, just put your mouth on it and blow really hard...
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    Hahaha...
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Jun 14 2007
    2000 S4
    Connecticut
    i like that compressor you have pictured casawhite... only thing is i bought it used it once, worked great, next time i went to use it the following day didnt work! SOB! so when i get money again i would like to rebuy it the 100 seemed better other places :)
