Results 1 to 15 of 15
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    OEM sport shocks, and aftermarket springs
    i know this has been discussed alot. but i havnt really seen much of a desicive(sp?) answer on this.. maybe because there isnt one..
    but is anyone running the OEM sport shocks, and aftermarket lowering springs?? are the sport shocks able to handle lower springs for the long run? like do you think i could run oem sport shocks and a conservative spring like eibach and be fine for few years??
    basically i have stock suspension. i am about to get an oem sport suspension installed. i plan down the line when i have money to buy some new wheels, then at that time i will buy springs and pay for another installation..
    now i am considering just putting the springs on now (and saving the cost of having to pay twice for installation). but what i DONT want to happen, is to lower my car now, and then get new wheels in a year or so, then by the time that happens my shocks are blown and im pissy
    im looking for answers, not necessaily opinions, and im not looking for advice as to whether i should buy coilovers or not.. i just really want to know if the sport shocks can handle lower springs.. does anyone have any first hand info??
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    Re: OEM sport shocks, and aftermarket springs
    just installed my h&r sport springs and didn't bother with aftermarket shocks (i.e. koni).
    im very happy with the ride height and its not too bouncy. after i got the springs installed i went and got an alignment at the dealership.
    here's the thing: i leased my car. the service guy at the dealership said that since it's a leased car that i shouldn't bother with the shocks and just switch out the springs when i turn it in. however, if i keep the car after the lease is up (2.5 years) i'm gonna have to get new shocks.
    my guess is that the oem sport shocks will last 20k-25k with sport springs. also remember to get your wheels rotated and aligned every 5k or you'll wear out expensive tires real fast.
    May 20 2004
    More cars
    Never Land Ranch
    They handle better than the stock shocks on none sport, but just the same, they will wear out after than a spring and strut combo!
    Most people who get CO's don't change up their suspension after they get it to the "right" setting for their driving style. I have the Stasis CO's and i love them to death, but yet if there was a cup kit of some sort I would buy that and save money.
    If you plan on getting new wheels or raising or lowering your current setup the CO's will be best. I got a great deal on the CO's so i bought them for the same priceas springs and struts cost...
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Jun 09 2008
    b8
    hmm... i appreciate the info.. that 20k-25k mile range of how long the sport shocks will last was pretty much what i was looking to know
    what exactly does the car being lower have to do with the tires wearing out faster??
    my car isnt leased, but at the same time i usually only own the car for 2-3 years..so im thinking maybe just springs, then ill throw on the stock sport springs right before i sell
    Quote Originally Posted by lk1122 View Post
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    with oem sport shocks, H&R sport or Eibach Pro-kit should be ok. Keep in mind labor is not cheap and whether its shock/spring combo, coilover, or springs only labor will be the same. All installs require virtually the same procedures and time. Also you can resell a spring and shock or CO and recoup some of that money back.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Jan 10 2007
    VA
    even mild springs like Eibachs or H&Rs causes the shock valve to sit lower in the shock tube than designed. limiting its effectiveness and ultimately wearing it out faster than normal. If you plan to keep your car a while, and don't want the ride degrading a lot over time, pony up for better matching shocks. Or get coilovers...they're only a few hundred more than a spring/shock combo, and not only offer adjustability but handle quite a bit better. If your car is new and a lease, you can likely get by with springs and oem sport shocks, but don't be suprised if as time goes on you notice the car becoming bouncy.
    Jun 09 2008
    b8
    i actually heard that eibach springs were made to work with the OEM sport shocks.. is this true??
    May 01 2008
    Philadelphia
    I don't know exactly how lowering has an effect on the wheel wear...
    It has something to do with the wheels very slighty go in a different direction???
    Someone else chime in....
    May 01 2008
    Philadelphia
    wheels = tires
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    The rice bounce is annoying to look at and experience. Do it right the first time since the install labor will be the same and sell them when you return the car.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Senior Member Two Rings kevin2.0's Avatar
    Dec 06 2006
    Delaware
    Quote Originally Posted by JMG View Post
    I have H&R springs with the sport shocks and while I wouldn't say I necessarily regret not replacing the shocks, as they weren't (and still aren't) in my budget, I will definitely save up and do it right on my next car.
    May 20 2004
    More cars
    Never Land Ranch
    tires wear faster because angle of the toe(IIRC) unless you want to buy a $300ish toe kit
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Active Member One Ring FluidPrawn's Avatar
    Jul 01 2008
    2008 A4 2T, 2010 Q5 2T
    wisconsin
    Quote Originally Posted by SEXICAN View Post
    even if you get the car aligned after installation?
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Toe? I think you mean camber.
    The lower the car sits, the more negative camber the alignment will experience causing the inner part of the tire to wear faster than the outer part.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    May 20 2004
    More cars
    Never Land Ranch
    yep, sorry camber! the alignment won't help the tire wear!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
