Results 1 to 20 of 20
    Established Member Two Rings bradisonn's Avatar
    Jun 18 2008
    2001 A4 1.8T Sport Edition
    San Diego, CA
    Installing spark plugs: '01 1.8T
    I'm trying to install some new spark plugs in my 1.8T and I was gonna follow the AudiDIY.com guide but my car seems to be different.
    Notice the 8 coil bolts that need to be loosened to remove the plugs...mine does not have that. In fact, there are no bolts to remove...
    I was just wondering if anyone knew how to get to install the plugs in my year.
    2001.5 TIP Audi A4: Sport Edition, Brilliant Black, Chrome Exhaust Tips, NGK Laser Platinum Spark Plugs, 8000K HID headlight kit. Nothing really, just got my timing belt done at 86K
    Planning to get: RS4 Grill, Kicker Sound system, Clarion Double-Din Head Unit, 5% Rear 35% Front Windows Tint, HID fog lights, up to any suggestions...
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Re: Installing spark plugs: '01 1.8T
    Just grab the Coilpack and pull strait up.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Jun 18 2008
    San Diego, CA
    Really? I was going to do that but I wasn't sure if it would break anything. Alright, I guess I can finally install them when I get home tonight. Thanks!
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Those are different coil packs which are bolted down. For yours, just unplug the plugs from the coils and pull on the coils and they will just slide out. You will then be able to take out the spark plugs.
    Here is a guide to what plugs you need. Spark Plug 1.8T Guide
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Yeah, those coilpacks you have pictured aren't stock. Yours just pop out. Also, disconnecting them makes things a little easier.
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    It's pretty simple. I have the same car as you, except stick. Take off the cover, and you see the coil packs. Disconnect the wire harness from it, easy by pulling by hand or use flathead screwdriver. Since we don't have the bolts, you just pull up with a bit of force on the coil packs and it slides right out. Everything is the same as the AudiDIY.com guide after that. The bolt down type coil packs are from earlier model b5's. Ours is just by a nice snug fit.
    Just to finish off, use a socket wrench with 6" extension to unscrew the spark plugs. Might have to use some force to twist it loose at first if it was in there a long time, and make sure to twist with your legs. I twisted with my arms and ended up having my flesh ripped off on a finger from banging my hand the motor. At least I can truly state I put my sweat and blood into my car though.:) After that, put in new plugs and the coil packs in reverse order.
    Make sure to use a torque wrench to tighten spark plugs to 22 ft.lbs. I did my coil packs while I was at it, just for peace of mind. They went for 35 a piece at my local dealership. Used same sparkplugs as you. Search for more info on those two.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Jun 18 2008
    San Diego, CA
    yeah, it really confused me...i bought the NGK PFR6Q (OEM Platinum). I'm hoping there will be a significant difference in performance. I was reading that article you linked and the guy said it rode a lot smoother. That would be a nice inexpensive upgrade...
    Senior Member Three Rings 1a9u9d8i's Avatar
    1998 A4 2.8Q
    Minneapolis
    you are not going to notice a difference in changing spark plugs. unless your old ones were really fvcked up... a spark is a spark is a spark
    Jeff
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    I didn't read everyone's responses here - but make sure that if you are currently driving the Audi, don't just go home, pop the hood and start monkeying with the plugs. It's best to do it on a cold engine - you run a serious risk of screwing up the threads on an aluminum head if the engine is hot or even warm from just driving it.
    Jun 18 2008
    San Diego, CA
    will do, thanks for the heads up!
    and i might actually notice some difference then because i dont think they have ever been changed...
    Sold:1997 Audi A4
    Sounds like you didn't search on here. These cars run better on copper plugs. Platinum plugs last a long time their not good for performance
    Alex
    Jun 18 2008
    San Diego, CA
    huh, really? would there be a huge difference. How long do the copper plugs last?
    Oct 22 2006
    Quote Originally Posted by nebone22 View Post
    So with reading that article are we supposed to be gapped @ .032 or .028 im running ngk brk6e platinum(el cheapos) gapped @ .028 should it be .032? or should i get the 7e's and gap em to .032 or .0.28?
    Oct 25 2006
    Oxford, CT
    I change my plugs with every oil change - Any time the Service Engine or Service Oil indicators go on, I change my oil and I don't worry about it any other time. I use NGK BKR7E's at .28.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I have BKR6Es gapped at .028" and get no misfires while at full boost and normal driving but it tends to misfire and skip a beat at idle. These plugs do wear faster so then the electrode wears down, the gap gets larger. Guide says to use colder plugs BKR7Es for chipped cars but that plug should be used with K04 preferably.
    Senior Member Two Rings 00a4's Avatar
    Apr 07 2008
    parts
    NOVA/ NC
    Just found this thread and I'm going to change my sparks in the next few days. How do you get the gaps right and are there any issues that would come up with the ecu?
    "You can have a car in any color you like- as long as it's black"
    Oct 15 2010
    Fairlawn, OH
    Quote Originally Posted by 00a4 View Post
    With on of these (can be bought at your local parts store, where you are probably buying your plugs)
    NOT one of these
    Deactivated Two Rings
    Dec 16 2010
    2013 Leaf
    Camino, CA (Tahoe Area)
    Just checked out this thread. I'm new here. Have a 2001 A4 1.8 Avant with a stage one APR chip. Everything else stock. I live where it is cold but not below freezing very often. Can I use the 7E copper plugs or should I stick with the 6E's gapped to 0.28?? I'm confused. From what I've read I think everyone here is saying you should have a larger turbo to run the colder 7E?! Is that correct? Please give me some feedback on what I should run in my Avant. I would be willing to change them more often it it helped with performance....thanks in advance.....
    Jun 10 2010
    Dec 16 2010
    2013 Leaf
    awesome. thanks
    oh I printed that whole thins out!! But I still am unsure which one my car would fall under!! ?
