Results 1 to 11 of 11
    Registered Member Two Rings wiscaudi's Avatar
    Aug 03 2007
    Milwaukee, Wisconsin
    Fuel Nozzle Stuck While Filling Tank (Pics)
    I filled my tank up the other day and when I went to remove the filler nozzle from my car, it became stuck. I rotated it around a bit, and tried pulling from different angles. It finally came out, but now my gas cap won't screw on properly. I noticed a flange at the bottom of the receptacle that appears to be pulled up (and I assume that's what the filler nozzle got stuck on).
    Is this flange supposed to be here, or should it be completely flat?
    Also, my info display is indicating that my fuel door is open, when it does indeed close all the way and lock. Does that indicator also let you know when your gas cap isn't properly installed?
    I also have a steady CEL which I attribute the gas cap not properly sealing. I will VAG tonight to confirm.
    Thanks
    2003 B6 A4 1.8T Quattro 5 Speed
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Re: Fuel Nozzle Stuck While Filling Tank (Pics)
    Nope... try and tap it down and maybe see if thatll help or shave the cap alil after tapping it flat
    2018 C7.5 A65 3.0 S BB Bone Stock - for now.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    May 24 2007
    Southern California
    Quote Originally Posted by wiscaudi View Post
    the receptacle
    i notice how you used "receptacle" and your avatar is boeing.
    do you know anyone by the name of bob golles?
    Kyle
    2.0L Revo GTRS Eliminator
    Aug 03 2007
    Haha, picked up on the "aviation" terms (I suppose they're aviation terms).
    I don't know a Bob Golles. I work for an airline out of Milwaukee which flies all Boeing / McDonnell Douglas aircraft and also work hand in hand with Boeing fleet support.
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    I'm pretty sure that should be flat.
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Fix it with a blowtorch.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Sep 27 2006
    chicago
    Quote Originally Posted by WiZZLa View Post
    whoa
    '03 A4 3.0 Amulet Red
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    If you are going to try and fix that yourself, be careful not to make any sparks you dont want that thing blowing up in your face
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by El_Chapusca View Post
    Yes, it is safer to smoke a cigarette near gasoline than to create a bunch of sparks. I think this warrants a trip to a professional for repairs.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Three Rings A4Avant02's Avatar
    Feb 05 2008
    '02 A4 Avant, '74 Triumph TR 6
    Folsom, Cal
    Yeah, that 'flange' should not be there. Looks like the gas nozzle did a little unwanted metal work for you.
    Aug 03 2007
    Thanks for the info. This area has to be made of aluminum as is the fuel nozzle so no sparks are created when refueling.
    The flange looked almost like it came from production like that since the bend radius was pretty nice. Glad I asked.
    I'll see if I can get in there with a rubber mallet. If that doesn't work I'll try a long screwdriver and place the plastic handle end on the flange and tap the screw driving end with a rubber mallet.
