So I recently installed a gtrs eliminator kit and am having some issues with slow spool. My wastegate was adjusted so that it regulates boost at 5psi if I connect the charge pressure directly to the wastegate. (originally ATP sets the wastegate to 1bar)
Setup:
GTRS
Stock Exhaust Manifold no leaks (previously had 034 manifold and thought that might have been leaking, turns out it wasn't)
High-flow catalytic converter
MBC set to 20psi
is the wastegate setting I have too low leaking exhaust gasses and causing a slow spool? Or do you think the slow spool is because of boost leak, or other related issue?
so far i've tried pressure testing the system, found no leaks. switched to 710n. removed the n75 out of the equation.
