Results 1 to 12 of 12
    Jan 08 2007
    NEW YORK
    Oxygen Sensor Advice!
    It is time to change my oxygen sensors and I am very confused with what I am finding out there. Is there a significant difference between a $25 sensor versus a $70 or $130 sensor? Is there a difference between Bosch or Beck Arnley? Does it matter if I buy a universal sensor that needs to be spliced versus a more expensive direct fit? I appreciate the advice.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Oxygen Sensor Advice!
    I got the ones from Vast and they worked great. Be prepared for a bitch of an install. I would check out ECS for some different kinds of O2 wrenches. Damn drivers side took me hours.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    I used bosch univerisal. Very easy to do, and they work great. I think I paid 50 bucks each. Far cheapier then the OEM ones. All you have to do is splice in the stock plug. It's very easy.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    passenger side is super ez looking. just unscrew it and unplug it. like a 2 minute job. mine went bad and took my MAF with it. code P1139... So I need a new one. hope i can get it off a totalled a6
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I replaced both my front O2 sensors with the spliced sensors. I replaced the O2's on my car and on a buddy's A6 and both cars I didnt think they were hard at all to get out (either side) I did have a o2 socket, but not sure what brand it was, I borrowed it from a buddy.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jan 08 2007
    NEW YORK
    Where did you find the Bosch Universal for $50?
    Jul 07 2007
    Tempe, AZ
    ebay
    Established Member Two Rings Rane_kn's Avatar
    Jan 12 2008
    Orlando, FL
    I have to change one of mine too. I don't know which yet so I'm gonna do both. But my question is what is the difference between how many wires are with the universal ones? How many do our stock ones have?
    "Shit Happens Wear a Diaper"
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Do we need 3 or 4 wire O2's??
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Apr 05 2007
    Quote Originally Posted by OldYella View Post
    4-wire
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    Zoldmans from vast. Dont bother with anything else.
    Jan 08 2007
    NEW YORK
    I found the expensive Bosch Oxygen Senors with the housing attached and no splicing necessary from a company called PartsREX for $80 each. They usually go for $140+. Contact Moudy at [email protected]. Our cars take 4 Oxygen senors.
