Results 1 to 3 of 3
    Senior Member Two Rings itsbigj05's Avatar
    Nov 28 2007
    ducati 696 and mg midget
    Pittsburgh
    caliper slider stuck
    i was trying to replace my rear pads a rotors today, but one of the sliders on the caliper carrier is stuck. i pulled back the boot, sprayed it down, and tried to beat it loose with a hammer and had no luck. i also tried searching around for some answers, but i came up short.
    does anyone have any ideas on how to get the slider out, or do i need to replace the entire carrier?
    thanks
    jeff
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    Re: caliper slider stuck
    you can try removing the pads and then bolting the caliper back up and then use the caliper as leverage to push it back/out
    or remove the boot and get a pair or vice grips between the carrier and the head of the slide pin and beat on that
    or if those dont work u can drill a hole in the front side of the carrier and use a screw driver/hammer to back it out from the front
    -06 A4 2.0T
    -97 A4 1.8T
    Nov 28 2007
    Pittsburgh
    thanks for the help!
    i work at a golf course mowing grass so i took the carrier in today to have one of the mechanics get it loose. he even polished it and greased it up for me!
