Results 1 to 13 of 13
    Senior Member Two Rings Shi-Fu JaY's Avatar
    Apr 06 2008
    Fontana, SoCal
    Oil light came on after adding seafoam.
    I put seafoam in the crankcase yesterday night, drove around for about 10 miles, and the oil light came on in the center of the gauge cluster.
    so I checked the level dip stick and it was at proper level.
    turned the car back on, and the oil light was gone.
    Has this happend to anyone?
    anyone know what this means?
    I changed my oil already BTW :)
    been using mobil 1 oil, and mobil 1 large filter.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: Oil light came on after adding seafoam.
    oil pressure or oil level?
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Sea foam dramatically increases the viscosity of your engine oil. I expect that had something to do with your oil pressure light coming on.
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Apr 06 2008
    Fontana, SoCal
    the light that showed yesterday was in the square center screen, and it showed the oil thing, and oil dripping down, that must be the low oil level right? but it wasnt low on oil.
    the old oil (with seafoam) was watery. I read, its suppost to be like that.
    Dec 19 2007
    York, PA
    ^correct
    Jun 13 2005
    Minnesota
    Quote Originally Posted by Shi-Fu JaY View Post
    Oil pressure
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    If it increased the viscosity of the oil, should it not increase the oil pressure as well, since it is thicker? Why would it cause the low oil pressure light to turn on? If this is the case, then I think the OP should be weary of motor seals, from what I'm reading our cars are somewhat "sensitive" in crankcase seals department and a dramatic change in oil pressure can bust those.
    I've never used Seafoam, but is it like most other motor flushes? You run in in your engine with some conventional oil to get all the gunk and stuff out and then your drain it completely and replace it with the oil intended for regular use in the vehicle?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Senior Member Two Rings treemolecule's Avatar
    Jan 13 2008
    04 1.8TQ6M(^^sleepy car)
    Charlotte, NC
    Quote Originally Posted by 04QuattroTurbo View Post
    That's one of the uses for it, just like most crankcase flushes, but you can also suck it via vac line to the throttle plenum and then let it sit for 10 minutes, then it burns all the coked up oil and carbon deposits out of the exhaust, smells like ass wrapped in dirty sock too...
    [B]APR Stage 1+ and Snub Mount
    034 DensoLine Engine and Tranny Mounts
    GReddy Turbo Timer
    Forge TIP (RED)
    Jun 13 2005
    Minnesota
    My bad... I meant it decreases viscosity. Sorry for the confusion
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Did you drive for any longer than 10 miles? I heard its bad for the engine to drive for extended periods of time with seafoam in the engine. Did you change your oil immediately after?
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by tike0rz View Post
    If it decreases viscosity, then it is bad to drive on period. My understanding of motor flushes and the like, is to run in with pressure on idle and a few blips of the accelerator and then drain completely and use the oil you wanted to use for the car.
    USP Member 110
    Apr 06 2008
    Fontana, SoCal
    seafoam really broke down the old mobil 1 oil. I drove around for 10 miles then the light came on. pulled over, turned off the car and checked the dipstick.
    everything was fine, so I started the car up, and it was back to normal.
    I changed my oil the next morning. The car drives even better now. but im just wondering why the light came on when I added the seafoam.
    Jun 15 2008
    Fairfield, CA
    Because the car sensed the drop in oil pressure when the Sea Foam broke down the oil making it less viscous. If it does thin out your oil, then the system would have sensed the drop in oil pressure, giving you the warning. Maybe?
    USP Member 110
