Results 1 to 7 of 7
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    Just finished my stereo upgrade
    Went with...
    Infinity 50.9cs front components (custom adapters)
    Infinity 60.7 Rear speakers (crutchfield adapters)(speaker baffles)
    Alpine MRP300 4 channel amp
    Infinity Basslink 10 inch all in one sub
    4 gauge main wiring with fused splitter into 8 gauge wire for amps.
    Sounds great for alittle over $500 for the complete setup.
    I made the brackets for the components using the speaker grills that came with the speakers. I dremeled out and ground down a large portion of the door but in the end very clean solid speaker mounts for free! I had the bose system in my previous car and its nice to upgrade the nonbose to something better then the bose. (and this is much better) I complemented going with better components but for the type of music I listen to (rock) this sounds great.
    Im using a kenwood head unit untill I pull the trigger on a Pioneer F700BT and go for my double din conversion. Right now the pioneer units have thousands of bugs, just head over to avic411.com and have a read. I was considering the kenwood 8120 but the UI just hurts my eyes.
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Just finished my stereo upgrade
    How do you like the Basslink? I've heard mixed reviews.
    It's a good start. Just wait, it'll become an addiction.
    Veteran Member Four Rings Yevmeister's Avatar
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    Can you post pictures of how your front doors look,
    i was always thinking of 5.1/4 component upgrade without overdoing a door panel
    thanks in advance,
    Yev
    Jan 22 2007
    NNJ
    Quote Originally Posted by djwimbo View Post
    basslink sounds good for what I need it for. I was hoping the kappas a lone would be enough to satisfy my needs but they are extremely thin sounding without a sub and just arn't nice to listen to alone. I didn't want to add any weight to the car and the basslink is very lightweight (around 20 lbs speaker/amp/enclosure) This was one of the reasons going with it rather than one 10 in box with external amp. I found it locally used and managed to snag it for $150 with rca's, wiring, and fused distribution block. I have it right behind the drivers seat and wired so i can easily move it to the trunk If I need to on the fly. It fills the sound out and its nice and balanced. If I listened to rap music I might be dissapointed but I can hear my kick drum nice and tight in my back. To get the mix balanced I ended up turning the basslink gain all the way up and the 4 channel amp gain to about 25%. This isn't a problem because with the head unit up al the way the speakers are loud loud loud and crystal clear with no distortion whatsoever. Funny thing about the basslink is I am happier with it at higher volumes and don't hear it as much in the mix on lower volumes. I thought this would have been the opposite. Im definitely happy for $500 bucks I don't see any better way. I now want to hear a pair of $800 focal components bc to me these $250 speakers sound great, I can't imagine how good high end focals are.
    This also finally solved my 3 inch exhaust drone problem
    Yevmeister, fitting the 5 1/4's wasn't an easy task. Took me a few hours to get it perfect and mount the crossovers getting the door to fit snug. I will try to get some pictures. I basically dremeled down a lot of the door and used long screws with nylon bushings to make sure the speakers had enough clearance. The drivers side door took me a few hours but once I got it perfect the passanger only took maybe 20 minutes to do. I also was at a shop with air tools and tons of cutters and such handy.
    2012 Cayman S Track
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    i have been doing custom fiberglass door panels before, with my current car i don't want to get into another lengthy project
    i used to work in one of the shops in the area so the tools are not the issue, it's just i am very visual person and want to see what your door panel looks like with those components, so perhaps i will attempt something similar
    Yev
    Jan 22 2007
    NNJ
    Quote Originally Posted by Yevmeister View Post
    Yev
    Later tonight I will pop off one of the doors and post it here
    2012 Cayman S Track
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    Thanks much i can't wait
    Yev
