Results 1 to 12 of 12
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    LED Citylight users, where do you buy bulbs?
    I bought my first set of bulbs from UltraLEDs and I should have stocked up because they died after about 6-8 months. I bought replacements from SuperBrightLEDs and they died in an hour of use. Actually one turns on when I first turn my lights on then turns off lol, piece of trash.
    So my question to you is where do you find your bulbs that last at least a few months? I prefer the wide angle bulbs too.
    Dec 06 2007
    Re: LED Citylight users, where do you buy bulbs?
    ^^[email protected] i believe!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Member Buttafuco (i think thats how u spell it) is making plug and play LED city lights.
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Quote Originally Posted by AudiA4Turbo22 View Post
    I stopped carrying the LEDs after UlteaLEDs stopped making the wide angle version of the bulb which i found was the best LED bulb I could find.
    They have replaced it with some other bulb which I don't like as much and when they come out with a better solution that I have suggested I'll start stocking bulbs again.
    Dec 06 2007
    ^^my bad!
    -Kirk
    Dec 08 2006
    Jersey
    Quote Originally Posted by 02silverb6 View Post
    I'm using Winston's LED Citylight regulators now, my problem is the bulb not so much getting them to stay on
    Quote Originally Posted by [email protected] View Post
    I saw that bulb over the weekend and I was going to order it. Do you have a picture of the what it looks like installed by chance? I really need an LED bulb in there before Waterfest
    Jun 11 2005
    Vancouver, BC
    You got a link to the bulb you looked at?
    Dec 08 2006
    Jersey
    I beieve this is a new bulb because the last one I looked at was not wide angle.
    http://www.ultraleds.co.uk/uh6w1w-ba...er-p-1269.html
    Jun 11 2005
    Vancouver, BC
    Skip on that bulb as I tested them out and they get too hot.
    I am trying to talk them into making this bulb but in white:
    http://www.ultraleds.co.uk/leds-blue...lb-p-1595.html
    Dec 08 2006
    Jersey
    9 LEDs that go all the way around the bulb... I Like!!! BAX9 base though, right? I think filing the nub on my superbright leds bulb down may have something to do with they they died so fast.
    Jun 11 2005
    Vancouver, BC
    Filing the nub down does nothing to do with bulb life. The pin is there just to lock it in place into the socket.
    Don't know why you had such problems with your bulbs as I'm still running the first pair of wide angle bulbs I ever tested.
    Dec 08 2006
    Jersey
    Hmm, maybe I'll check my connections and see if everything is ok
