Results 1 to 11 of 11
Thread: Boost problem?
    Registered Member Two Rings mistert396's Avatar
    Apr 23 2007
    2001.5 S4
    Ft. Bragg, NC
    Boost problem?
    I started noticing that when Im hitting boost my car seems like its kind of surging and struggling to get there. Then today on my way back to the house I was looking at it a little more and it would hit boost spool to 17 psi and then it would shut off to 5 psi. Is this limp mode? If so what could be causing this? Im currently searching for boost leaks and wanted to see what you guys think. Thanks in advance.
    Stage I
    GIAC, 710n, Darintake, JHM Tranny rebuild, Cheapo Ebay Short Shifter, Vast Stage 2 Clutch, APR Vent
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: Boost problem?
    TBB....I had the same problem. When I got to 12 PSI I would hear a rush of air and I would loose power. I found 4 tears in my TBB. Samco TBB and problem solved for me.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Boost problem?
    5psi is definitely limp mode. I would pressure test first. TBB is a good place to check.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 23 2007
    2001.5 S4
    Ft. Bragg, NC
    Re: Boost problem?
    Thanks for the reply's. If it is the TBB would you recommend replacing it with Samco? I've heard that using the APR Bi Pipe gets rid of this problem as well. Also is it something that needs to be fixed ASAP or would it be alright to wait a week or so?
    Stage I
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Boost problem?
    Quote Originally Posted by mistert396 View Post
    If it is your tbb, I would get it fixed ASAP. The bipipe will fix torn tbb problems, it's also about 5 times the cost of a silicon tbb.
    Apr 23 2007
    2001.5 S4
    Ft. Bragg, NC
    Re: Boost problem?
    Alright, after doing another test drive with it, its acting differently now. The boost is coming on strong to 15 psi but then it seems to be in an in-between mode. It is surging like full boost and then none. It does this repeatedly while holding down the gas pedal. Is this typical of the TBB or possibly the diverter valves. I know those will soon need to be replaced as well.
    Stage I
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Boost problem?
    You should pressure test/VAG the car. If you still have stock diverters, then yes, they should be replaced as well.
    Oct 30 2007
    Pasadena, MD
    Re: Boost problem?
    I would be willing to bet money you need a new TBB. I bet I can even tell you where its torn. Its torn along the clamp that holds it to the throtle body. Check it.
    Apr 23 2007
    2001.5 S4
    Ft. Bragg, NC
    Re: Boost problem?
    Haha right on the money. Good call man. I will get it fixed as soon as my Samco shows up. Thanks.
    Stage I
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Boost problem?
    Quote Originally Posted by 2k1audiS4 View Post
    That's a bold statement..I'd take some of that action if I hadn't sworn off gambling But yeah, they do commonly rip there. Here's what mine looked like.
    Oct 30 2007
    Pasadena, MD
    Re: Boost problem?
    ^^^^Same place mine ripped except about 4 more places around that edge. I think Audi should do a re-call on all TBB's and give everyone samco boots. I know it would never happen but just wishfull thinking i guess.
