Results 1 to 7 of 7
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    Two questions (suspension & brakes)
    I have a 99 a4 1.8t quattro of course. I took it to the shop to have a alignment done on it ans they told me the upper passenger side ball joint is shot, so working at a shop myself i told them i will just replace them on my own, and then have them align it. I was wondering if anyone knows of anywhere to get a set of ball joints for it, (I have checked techtonicstuning, germanauto parts, and awe tuning). And maybe give my some insight on how hard of a job it might be.
    Second, sometimes when im driveng the car will flash the brake light at me and beep three times and go off. I remember hearing something about it being something with the brake pads getting low, but i just wanted to make sure its not anything with the abs like a speed sensor or a tone ring or anything like that. I took a peek at the rear pads through the rim and the pads are getting a little low and the rotors have a bit of a lip on them. So it would make sense to me that it has something to do with the pad life.
    Thanks a bunch guys.
    Deactivated Two Rings
    Aug 28 2007
    Re: Two questions (suspension & brakes)
    there are no pad sensor on the rear breaks so in my opinion your lights have nothing to do with the pads.
    It sounds like your abs module has a problem..if you're lucky, its a bad wheel sensor or tone ring.
    Good luck
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    the ball joint is actually the upper control arm, which is a common failure on the A4
    Dec 14 2006
    Halifax, NS, Canada
    you have to get whole new arms. might as well do them all.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Mar 24 2008
    Illinois
    thats what i was thinking. Im just going to replace the uppers, since the lowers are still ok and they are $250 something a piece.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The beeps are low brake fluid.
    Jim
    I Do Werk.
    Dec 14 2006
    Halifax, NS, Canada
    Quote Originally Posted by arorem View Post
    where are you getting those the dealer
    NOW DEAD :(
