Results 1 to 10 of 10
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    Blinking Check Engine Light for about 30 sec.
    I recently installed the Podi Gauge and now able to monitor my boost. Over the weekend I was getting onto the Highway and decided to do some spirited driving. I got onto the on-ramp and in 3rd gear gave it full throttle. The gauge read 11 psi until I shifted to 4th. I didn't red line or anything, but all the sudden after I shifted the check engine light started to blink so I let off the gas a bit and drove normal. 30 sec. to a minute later the light went away. Is this something to be alarmed about?
    Oct 31 2005
    Ashburn
    Re: Blinking Check Engine Light for about 30 sec.
    The blinking CEL meens you have a misfire in one of your cylinders. It could range from a bad spark plug, to coilpacks, injector, or even a boost leak.
    What are your mods? Do you know how to pressure test / have access to a VAG-tool?
    - Instagram: @Sinister_rs5-
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    dont do that again until you get it sorted out.
    SBSC
    I also like to live dangerously.
    Feb 15 2007
    San Mateo, CA
    Thanks for the fast reply. The car is completely stock and I don't have access to a VAG or have the proper equipment to do a pressure test. I'll look into getting the car scanned sometime this week.
    In regards to boost leak. This is my first turbo car and had some question in-regards to boost. I've noticed that in all gears that the car normally runs on vacuum (in.Hg) on the gauge. It rarely goes above 1-3 PSI unless the car is really driven hard. Is this normal? I can only get it to 10 PSI in the higher rpm's.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Where is Foster City?
    Anywhere near LA? If so I can VAG your car.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - Kevin@socals4.com
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    ^^ Boost only builds under load, so what you're describing sounds about right.
    Aug 28 2007
    NKY
    Thought a blinking CEL meant damage is being done to your Catalytic Converter, no?
    - Jared
    Current: ‘18 Daytona Gray RS3 (Technology Package, Dynamic Package, Black Optics, RS Design Interior)
    Gone: B8 S4 Stage 1 —> C5 A6 2.7T Stage 2+
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Pearl_2.7T View Post
    - Jared
    Random/multiple cylinder misfires detected.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I would double check your boost gauge set up. Sounds like you have a leak somewhere in it.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Feb 15 2007
    San Mateo, CA
    Foster City is in between San Jose and San Francisco. Next to San Mateo.
    Quote Originally Posted by Rated S View Post
