    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    APR Snub Questions....HELP!
    Well I'm going down to APR on friday for them to reflash to stage 1+ (im just stage 1 right now) and i was thinking about having them throw on a snub mount for me....would it be worth the extra money to have them do it and do it right (hourly fee is $100) or should i do it myself? is it really that easy? is the mod even worth it?
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: APR Snub Questions....HELP!
    you can do it "right" in 20 minutes:
    CLICKY CLICK
    and:
    http://www.goapr.com/Audi/support/b6_snub_mount.pdf
    They won't have any reason to take off your belly pan if you're just getting flashed, so you won't be saving any time by having them do it.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Three Rings plug1's Avatar
    Mar 31 2008
    Colorado Springs
    Yes it's easy and yes it's worth it. Just DIY and save some money.
    Buncha motorcycles
    Memphis, TN
    OMG, please DIY and save $100 or just send me a $100 cause you are just throwing it away to have APR do it.. even the injector install is quite easy, they have instructions on their website
    APR Stage 2/AWE Intake
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Yeah, dont worry, maybe it seems to be a bit "hard" but it is much easier. U will understand when u unscrew the first bolt :)))
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
