Results 1 to 7 of 7
    Senior Member Three Rings spxxx's Avatar
    Jul 31 2007
    bay area
    ecu compatibility
    will an AEB coded ECU 557n fit a car that originally had an ECU coded for AEB with code 557p???
    Laser Red 1.8tqm GT2X pc16 --> sold
    REVO + 034 Goodies >>> B6 A4 1.8tqm
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: ecu compatibility
    If the plugs are compatible, then yes, they'll be interchangeable.
    Audi tend to put tags on plugs, to prevent mistaken connectivity between incompatible units.
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Yes. But you might have to change the soft code if the options are different from the donor car.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Jul 02 2008
    1999.5 A4 1.8T Quattro
    Danbury, CT
    bringing this back up top.
    how do you change the Soft code? i got a pc-16 file with a ecu that says 577N and mine is a 577P. I havent installed it yet but i dont want any downtime while i figure out if it will work.
    How would you know if the soft code has to be reset?
    Sold:1997 Audi A4
    Quote Originally Posted by AEB A4 View Post
    You need a Vag-com. Go to www.ross-tech.com you find the directions there. FYI you only need to change the soft codes if car had different options. Frontrak or Quattro Auto or 5 speed ...ETC.
    Alex
    Jul 02 2008
    Danbury, CT
    ok, the guy who had it before me had the same car as me ( manual, quattro, 1.8t AEB, etc. etc.) so i think i should be fine then, thanks for the fast response
    Sold:1997 Audi A4
    Yep you don't need anything if your options were the same.
    Alex
