Results 1 to 28 of 28
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Rear windows + Auto UP?
    Hey, is there any way to make the rear windows have the auto up feature as well?
    Thanks
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Rear windows + Auto UP?
    HeY J this might do it.
    May 22 2008
    is full of crap
    sandville
    oh crap, I just noticed something about ^ ^ ^
    ......idea is sound but the connector I don't know
    Another
    link this time from a VAG board.
    Sep 30 2007
    Upstate, NY
    only problem, they conflict with eachother.... one says to tie pins 5 and 7 together, the other says tie 5 and 8 together....
    so which one is it?
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    There's a reason the rears in most cars are not auto up.
    Children.
    May 22 2008
    is full of crap
    sandville
    Quote Originally Posted by Jared71482 View Post
    so which one is it?
    yeah I saw that. I don't know which is right either... a lot of help I am right
    Sep 30 2007
    Upstate, NY
    Quote Originally Posted by Siena View Post
    Children.
    oh i know that...
    a: i dont have kids
    b: the windows stop if they hit an obstruction.
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    speaker wire and a philips head all you need
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    May 22 2008
    is full of crap
    sandville
    I want to do this mod too.
    so which one is it?
    If both mods truly work, I guess the heavy red wire #7 and the lighter gauge one #8 both have 12V on them. I wonder if the little one is switched 12V.
    another link to a thread on this with a pic here.
    Sep 30 2007
    Upstate, NY
    Re: I want to do this mod too.
    Quote Originally Posted by MattzWarsteiner View Post
    That would be my guess... if I get the time this week i'm going to do this and i'll report back with my findings.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Hell, I read this thread at 8:29 and reminded me I wanted to do this about 2 years ago... At 8:31 I went outside... I tried both 5-7 and 5-8... Both work just fine... It is now 8:59 and that is after taking a dump and getting a beer... So, if that answers your question... Plus it is UBER easy!
    ΜΟΛΩΝ ΛΑΒΕ
    May 22 2008
    is full of crap
    sandville
    ^^ Lol You the man then ^ ^
    Let me ask you this, do the rear windows work with the key off now and was it #7 or #8.. before *cough* #2.
    Mar 04 2007
    nothing
    nowhere
    No, windows do not work with the key off... As I said, both 7 and 8 worked... I chose 7 because of the larger wire... I don't like to overwork the little guys... What was #2? What I found ususual, is that the write-ups all had blanks in #5... I actually had a wire there...
    ΜΟΛΩΝ ΛΑΒΕ
    May 22 2008
    is full of crap
    sandville
    ^ ^ Cool ^ ^ Thanks. Ewok_F.
    That's interesting about the wire in position 5. I'm going to guess that the #8 position is always on 12VDC since some report their rears work with the key off after the mod. I will do this sooner than planned after your inspiration.
    What was #2?
    Lol....for me it is what was consumed the day before.
    Mar 04 2007
    nothing
    nowhere
    With people reporting their windows working with the key off... There is something like a 2-5 mintue timer that will allow you to roll your windows up/down after the car has been turned off, as long as no doors are opened... That might be it! I don't see why there would be a constant 12V on a window...
    ΜΟΛΩΝ ΛΑΒΕ
    Registered Member Two Rings
    Jul 06 2008
    2001 Audi A4 1.8T
    how about using the remote to open/close windows? Will both 7 and 8 work?
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by hawaii View Post
    that is done via vagcom. no hardware mods...
    ΜΟΛΩΝ ΛΑΒΕ
    Jul 06 2008
    2001 Audi A4 1.8T
    Quote Originally Posted by Ewok_Fetus View Post
    I mean will the wiring of 5-7 or 5-8 affect this feature? I already had this mod.
    May 22 2008
    is full of crap
    sandville
    ^^^ Since the remote window mod uses the same circuit as the key in door method, it should not matter.
    Jul 06 2008
    2001 Audi A4 1.8T
    finally get a "mechanical" mod that I can finish by myself. Haha. However, it's very scary that the windows even cannot go "one touch down" after I connected everything and put everything back in. But both the "one touch up" and "one touch down" start to work after I tried several times.
    Mar 04 2007
    nothing
    nowhere
    They had to learn the one touch feature after you disconnected them... Perfectly normal...
    ΜΟΛΩΝ ΛΑΒΕ
    Sep 30 2007
    Upstate, NY
    I puttered around with mine the other night... found that both 7 and 8 have constant power all the time. However, #1 is switched... has power whenever the windows work...
    I'll hopefully get to it this weekend and get it all done.
    Mar 04 2007
    nothing
    nowhere
    Nm
    ΜΟΛΩΝ ΛΑΒΕ
    Sep 30 2007
    Upstate, NY
    Ok, all done... used some wires from a broken headlight connector... its the correct terminal and has the silicone seal as well, so all looks OEM. I ended up tapping into the #1 wire, which as I mentioned before, has power only when the windows will work. All works great!
    Jul 06 2008
    2001 Audi A4 1.8T
    then what's the difference between 5-1, 5-7 and 5-8?
    Sep 30 2007
    Upstate, NY
    # 7 & 8 both have power all the time, #1 has power only when the windows work.
    Jul 06 2008
    2001 Audi A4 1.8T
    but will there be any drawbacks if I connect to 7 or 8?
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Children.
    My B7 has auto-up all around from the factory.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
