Results 1 to 3 of 3
    Registered Member One Ring SilvBullet2.8's Avatar
    Oct 02 2004
    Carbon Fiber Hood Prop Shock
    I just got a fiber image hood and want to have the same hood raising shock like the stock hood. I know that the OEM shock is too powerful so I will need a less powerful one and some way to mount it to the hood. Anyone have any ideas?
    I really dont want to have some halfassed piece of metal or wood holding it up so only that shock.
    Thanks
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Carbon Fiber Hood Prop Shock
    My cousin put a CF hood on a 200SX a few years back and changed the mount points on the hood to compensate. Forward on the hood end IIRC. It worked but wasn't pretty. Boys rolling in a G35 2 door now. heh.
    A better solution.....get shocks with a valve so you can reduce the oomph by venting some of the gas inside....not too much tho..... ; ^ )
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    QuickLifts Plus or Elite. You can see if you can use a set they make for another car or if they sell a universal kit that you can then mount to any CF hood.
