Results 1 to 37 of 37
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    custom intake and a new pic of my car
    just got done making a custom intake and fitting a heatshield in between the turbo/intake piping. as well as installing a breather for the SAI pump. and i figured i would post the last pic i took of the car before i install the neuspeed race springs and koni's. so go ahead and hate on my wheel to fender gaps they will be gone in the next few days
    4inch cone filter with custom adapter from 2 1/2" to 4" and heat shield re-location
    my car with flat black oem sport wheels and badgeless grill
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: custom intake and a new pic of my car
    I was thinking about doing a similar cone filter/heatshield setup myself. How does the engine sound with the cone filter installed? and did the filter for the SAI come with the big one?
    {99.5 Avant}
    Veteran Member Three Rings -Audi_tuning-'s Avatar
    Jan 15 2007
    97boxster/08 A4/10 A8L/09Q7/04 S60R
    Nashua
    PUT THOSE RINGA BACK ON THAT GRILL ASAP lol...jk, looks nice with the blacked out grills
    -german_tuned-
    2 low 2 go
    Bag Riders... the only way to do air
    Deactivated Two Rings
    Nov 10 2007
    i see u have the offroad suspension that i have as well
    Feb 06 2008
    the small filter is just a 1/2 inch inlet with some electrical tape wrapped around it to match the inside diameter of the SAI inlet, and no it didnt come with the big one. The only time i notice a sound difference is at WOT you hear the turbo spooling up but engine noise hasnt changed... If anyone is interested i can put a whole kit together for about $60 including shipping i had the custom adapter made to go from 2 1/2" to 4"
    snailspeed.net
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Heatshield included?^^^^^
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Looks good and all, but I cant see how that heatshield would benefit.....It doesnt span form front to back...
    -Sami-
    Feb 06 2008
    yes the heatshield is included, because you just reuse the one attached to the factory airbox with the little custom bracket i made.. i include instructions with the kit for removal of factory airbox and installation of the new intake, it works even better with a TIP upgrade, i made one for my friend with a neuspeed TIP and it sounds amazing with an exhaust. and you hear the DV alot more. the kit i came up with allows you to reinstall the factory airbox, there is absolutely no modification to any part of the car.
    snailspeed.net
    Feb 06 2008
    well after some spirited driving you can touch the filter and its only warm to the touch where the heat shield is blazing as is everything on the engine side of it, it doesnt do as much as i would like absolute, but it is definitely better than none at all. i am working on a better solution but havnt had the time yet. but whats it matter if its a warm air intake, a front mount will cool the air down enough for it not to matter. i dont know if i would use it on a completely stock car
    snailspeed.net
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    I doubt that the shield does anything
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by eg6siR View Post
    The FMIC will only help so much, so the warmer the air is going into the turbo the higher the IAT's will be after the FMIC.
    Because the heat shield doesn't go all the way forward to the radiator support your filter is getting hot air coming from the radiator. I have measured temps behind the radiator while driving in 70F degs and the temp sensor was reading over 125F degs.
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    Cool, I want to do something similar to my 3.0 only with a bigger heat shield that separates the filter from the engine better. Also you didn't leave the stock fresh air inlet tube on there? I figure it may not do a thing, but it also might help get a little cold air to the filter as well.
    Looking for a good shop north of Boston, call Eurosport Performance
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    The mess above the filter looks ghastly, and all I can intuit it sucking in is warm to hot air.
    What's so bad about the OEM airbox in the first place (other than, perhaps, the look)? If it's sound you're after it's hard to beat the $0 swiss-cheese-airbox mod, which I can vouch for.
    And I'd second taking absolutegtr's and Mike's suggestion about the heatshield...
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Feb 06 2008
    i totally agree with you mike, i have been doing some temp tests as well with my laser style digital thermometer i got from mac tools, the heat shield isnt as good as it could be but it definitely cooled the filter down alot from the test drive i did w/o it. i am in the process of fabricating a better heat shield with some sort of ducting coming into the area from the grill area. thanks for all the input gentlemen, its definitely still a work in progress, i am gonna put on a new TIP soon and complete the heat shield. and then if anyone wants to buy a kit, i will have some for sale...
    snailspeed.net
    Sep 02 2005
    Montreal
    Hot Air Intake. Waste of money and time.
    Feb 06 2008
    Quote Originally Posted by Tactic12 View Post
    i am not daily driving the car, i am just kind of using it to make some parts at the moment, i am just kind of fitting things i am going to use on my BAT project, me and clint are coming up with a custom equal length tubular manifold to use on his car and my car in the next few monthes. and the wires are going to be re-routed soon i was thinking of doing a wire tuck on most of the engine bay. everything i have right now is just temporary as i mock up certain parts of the kit i am fabricating.
    snailspeed.net
    Feb 06 2008
    i have been monitoring IAT's and they havnt changed... even when i drive the car a little hard....
    snailspeed.net
    Sep 02 2005
    Montreal
    No change, then what's the point of investing money, no matter how little, and time?
    Feb 06 2008
    i was not looking for a change in IAT, i was looking for a little better throttle response and i got an improvement... its still nothing like a naturally aspirated engines throttle response but its better than it was factory and to me it was worth it. i spent about $50 and i dont think thats alot of money, even if in your mind i wasted it
    snailspeed.net
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    you really need a bigger shield that can stretch near the headlight and taller. in the summer, when you have AC on, the fan will blow all the hot air to everywhere of your engine, that shield you have now doesn't do shit.
    good luck fabricating a new shield
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Feb 06 2008
    Quote Originally Posted by Maverick View Post
    i have never used the AC in this car, i dont even know if it works.... i prefer the windows down... but that is a good point and i am working on that new heatshield
    snailspeed.net
    May 03 2007
    german
    heaven/hell
    are you cold blooded? lol j/k
    remember to wrap the shield with something that dissipate heat very well like the stuff they use in NASCAR.
    Sep 02 2005
    Montreal
    That makes no sense, you want to do the opposite. You want your shield to insulate, to reflect the heat, instead of absorbing it. It’s a heat shield, not a heat sink.
    May 03 2007
    german
    heaven/hell
    dissipate heat doesn't mean absorb the heat. if you don't wrap the shield, the shield will get hotter. but if you apply some materials that dissipate heat, the shield will stay cooler, so the air on the filter side will stay cooler as well. that's how I see it
    Sep 02 2005
    Montreal
    You first have to absorb to be able to dissipate.
    Jun 28 2007
    Edmonton, AB
    Pronunciation:
    \ˈdi-sə-ˌpāt\
    Function:
    verb
    transitive verb 1c: to lose (as heat or electricity)
    intransitive verb 1: to break up and scatter or vanish <the clouds soon dissipated>
    May 03 2007
    german
    heaven/hell
    i am out. lol
    whatever it is, good luck to the OP
    Feb 19 2007
    Charleston, SC
    Here is what I made and used to sell:
    (The factory air snorkel slips right into place to, so it would literally seal right up and it would seal with the hood as well.
    -Sami-
    Sep 02 2005
    Montreal
    With a heat wrapped cat/tp, that looks like a good setup.
    Feb 06 2008
    that is pretty nice looking absolute... i may try and fab up something similar, what material did you use? right now i am just playing with everything and planning out a topmount tubular equal length manifold for a BAT setup, i have the collector made, and i just need to play with tubing placement to stay equal length, hopefully will be using all vband setup as well, except turbo to mani flange. and where can i get some custom tuning done... anyone know? i am not gonna blow up my engine with some off the shelf software.
    snailspeed.net
    Dec 06 2007
    just to tell u, i have the same filter setup but in red, and that little breather filter u'll find will keep falling off after awhle, the tape from the heat becomes thinner!
    -Kirk
    BetaAlphaTau Member #58
    Oct 29 2005
    10speed
    San Francisco, CA
    me and clint are coming up with a custom equal length tubular manifold to use on his car and my car in the next few months
    woot
    - Clint
    Mar 12 2008
    CHI-TOWN
    i did the same thin but i am now working onmaking a custom pipe to run it to a coleder spt of the egin so it works as a true cold air intake right now i am in the proces making a templet out f pvc and then buy some pipe and have it bent to the pvc templet but u have to no that even with ur heat sheild that u are sucking mass amounts of heat
    Mar 27 2005
    The Cold North
    i think you need a little more heat sheild. MattA4 (B5 owner) make a bigger heat sheild for cheap.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    you guys are haters.
    did you gain any power? did your gas mileage change?
    Jul 07 2004
    socal
    Quote Originally Posted by BARRY View Post
    Its not like CAI's are a new thing on the A4 1.8T, people have been doing them since the B5 came out in 97.
    The K03 doesn't exactly flow enough air to cause the stock box to be a huge restriction and to get gains with a cone filter you must get more fresh air from outside the engine bay.
    When testing a CAI with a K03 back in 00-01, I was able to drop .3 off my ET's at the drags when getting very little fresh air to the filter vs running no head light to get fresh air directly to the filter. I again saw the same difference when running a T28 setup.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    A good start. This reminds me I need to fab up a heatshield for my intake prior to going on the dyno for final tuning. If you think your engine compartment is hot, you should see mine.
    -Doug
