Results 1 to 9 of 9
    Registered Member One Ring Letmepassufool's Avatar
    Jun 02 2008
    Newark, DE
    Isnt there a better setup for the GT2871R on 99 1.8T than this??
    I have the same setup as in this link....
    http://www.audizine.com/forum/showthread.php?t=221435
    And I hate it. It makes zero sense to suck in all that hot air and I'm looking for some pics or diagrams of others that have routed it to the area of the old air box. Being that this turbo setup has very limited room, I'd like to see if anyone else has tackled this successfully.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Isnt there a better setup for the GT2871R on 99 1.8T than this??
    Ive seen other setups where they have some sort of other TIP that allows them to have room for a heatshield inbetween. I doubt every 71R intake system looks like that BTW,.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 02 2008
    Newark, DE
    Well I know others have gone in other directions but when I bought mine, the guy had it set up this way (which I still have it) so now that I've gotten to it, I want to change it up. I just havent seen many applications visually. If you could find some pics or more info, I'd greatly appreciate it.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You could try one of these which is 3" on both ends, you can get it from ATP.
    Jun 02 2008
    Newark, DE
    Looks like it'd work but it just seems too restrictive. I guess I only have so many options though..
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    thats what i was trying to get out of that thread but i couldnt get too many pics
    2004 Subaru Impreza WRX
    Aspen White
    Jul 07 2004
    socal
    Quote Originally Posted by Letmepassufool View Post
    It isn't restrictive because the tube gets wider in the center section which keeps the volume the same as the inlet/outlets. I ran the same type of design in a 4" for my GT35r and was able to make 400+whp running 20psi.
    BTW on any 90 deg bend hose nearly all of the air is flowing at the outer edge, so a normal 90 would be more restrictive then the cobra which has more surface area on that outer edge.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    i do believe that was also ians (k0mpressed) solution to an intake for his 3076
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jun 02 2008
    Newark, DE
    Nice. Thinking of trying it out. Like I said, cant be any worse than what I have now..
