Results 1 to 9 of 9
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    A/C still blowing warm afte 3 attempts to fix!!
    It sux to be me right now..After 3 attempts at the dealer within the last 9 months to re-charge the air-con..its blowing warm air again!! I took delivery of my 2.0 back on Feb' 2006..the a/c worked fine up until October 2007..took it to Penske Audi..great guys and they have resolved a few prior issues with no prob..i was told way back then they could not find any fault codes when VAGing and when adding "blue dye" to the system..they couldn't find any leakage..refrigerant was added and I was good to go..within 5 days it started blowin' warm air. I didnt use the AC during our "winter" here in So Cali and didnt return to the dealership until Feb 2007..exact same outcome..within a week the refrigerant obviously is escaping somewhere and its warm azz air..left it alone then i finally freed up some time to return to Penske 2 weeks ago..u guessed it..computer shows no probs with A/C..no visible blue-dye ...and its holding the charge during their 1/2 hour leak test...WTF can it be??? Any leads as to what part within a/c system they should suspect?? Evaporator/condensor?? Its 100 degrees now and no end in sight!!!!!..
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Veteran Member Three Rings A4RingPimp's Avatar
    May 24 2008
    DG '06 A4/ '08 Land Rover LR2
    On a peninsula
    Re: A/C still blowing warm afte 3 attempts to fix!!
    If it's still under warranty leave it with them and tell them you don't want it back until it's fixed. Something is obviously wrong.
    Stand your ground!!!
    Have you ever seen the movie...
    The Secret?
    This guy is amazing!
    Six Minutes Can Change Your Life! Find Out How.
    http://store.sixminutestosuccess.com/?aid=590822
    Established Member Two Rings hhuynh14's Avatar
    Jul 01 2008
    2008 A4
    Orange County
    happen to me and the first day I got mine... took it back and they change a restrictor that went bad... ask them to take a look at that...
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Quote Originally Posted by A4RingPimp View Post
    Normally I wouldn't go this route, but for once I have to agree with someone on here. You have to leave it with them. Your A/C is supposed to work...plain and simple. If not the car is a lemon and they owe you a new car (if that still applies). I know you say they've been good to you but you have to show how unsatisfied you are with the result of what has happened even though you are satisfied with their customer service. Good luck. If worst case take it to an A/C technician, but beware as some of these guys are out to get your money. P.S. You have to to run the A/C in the winter or else there's a part of the system that has to stay "moist" and will dry if you don't run it for long times at a time which would also cause a leak. Anyways, they need to fix it.
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    You don't have the 'econ' button on right?
    Gotta ask...
    The condensor should be fine. Have you been in any fender benders at all?
    Apr 18 2008
    Jacksonville, FL
    only read the subject. if your vehicle goes in for service 3 times and it's still not fixed, lemon law applies. demand it be fixed on their dime or you get a new car. tell them if you get it back again with it not fixed, you'll be contacting your attorney.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    My A/C would blow warm about a week after I got my A4. It turned out to be a faulty outside temperature sensor which made the A/C system think that it was winter out when it was 100 degrees outside, shutting off the compressor so it wouldn't freeze.
    You may want to have them check the outside temp sensor. Does your cluster display the right outside temperature?
    Once they replaced my outside temp sensor my A/C worked fine again...
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    lemon law if they can't fix it after 3 tries in NY. Check local laws in Cali!!
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Feb 20 2006
    Thanks guys for the advice..I'm submitting my story to a leading Cali lemon-law attorney that will look further into it.."Fight for your Rights!"- The Clash
