16,000 negotiable.
Interior is black leather w. aluminum sport interior trim
Sport cold weather package w/ ski sack and heated seats.
The stock avus are now painted black and are in really rough shape besides that and the front bumper needs to be replaced it is cracked/busted from hitting a snowbank.
109,000 A.W.E Stage 3 audi s4.
6 speed manual transmission.
There were over 10k in shop repairs within the last month.
I have all the shop records from Avalon Motorsports.
The reasoning behind the 10k in repairs was due to an engine fire.
The ecu wiring harness had sat on the mani and melted a few of the wires.
So insurance gave them the go to just replace everything. So ALL the sensors connecting to the ECU have been replaced. Even the Ecu.
I have all the reciepts/documentation available upon request.
If you have anymore questions please email me.
The title of the car is clean.
75.00 Vehicle speed sensor.
2 new egt sensor 620.00
2 new ignition control units 502.00
1 mass airflow sensor 210.00
New wiring harness 1350.00
2 new knock sensors. 115. total
All new oxygen sensors 223.00 ea. (just installed a month ago)
400.00 Eibach springs
400.00 New power steering pump and labor
70.00 New 710's Diverter Valves
650.00 Southbend OFE Feramic Clutch disc and PP (intalled 3k miles ago)
400.00 Awe Lightweight Flywheel (installed 3k miles ago)
160.00 toy guy short shifter
75.00 rs4 grill
2500.00 awe fueling (93 pump ECU, 42lbs green giants, A.W.E 93mm maf and maf hose)
5 program ECU (stock, race gas, 93 oct pump, Kill, valet)
2500.00 rebuilt transmission from Autosportwerks (similar to a stasis rebuit trans)
200.00 ECS drilled rotors
100.00 Hawk hps brakes
60.00 brakes and rotors labor
600.00 uuc vm3 exhaust
350.00 piggie pipes
2150.00 ko4's
500.00 ko4 inlets
100.00 ko4 harware
400.00 timing belt
1440.00 install of ko4's and timing belt (both were installed at 98k miles)
75.00 bmw lip spoiler
60.00 Apr Snub mount
150.00 new crank positioning sensor
120.00 Aux coolant pump
150.00 install of new crank positioning sensor
300.00 new compass mirror from a6
100.00 install of awe fueling
200.00 rs4 motor mounts
160.00 wheel bearings fronts
122.00 Bosch platnins Spark Plugs
