    Veteran Member Three Rings trautob's Avatar
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    POP noise when on it
    I am experiencing a loss in power when I apply the gas hard. Ill be in any gear and when I push the gas hard it hesitates and makes a pop noise coming from the front, this isnt back pressure from the exhaust its like the DV is leaking or something. I put a new DV on today, and it helped the problem but still there. Im not sure if its a boost problem or something more serious.
    Veteran Member Three Rings audi314's Avatar
    Oct 22 2007
    06 A6 C6 Avant, 12 F-150 FX4 Twin Turbo
    ATL
    Re: POP noise when on it
    I would say your first thing to do is do a leak check see if your just dumping out boost. It might also be a backfire in the engine, how old are your plugs?
    I had a BT Audi!****> Lost at Barber MSP 11/1/09
    Hero-->http://www.youtube.com/watch?v=Q3gN6...eature=related
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    brand new plugs installed like 4k miles ago. Just did a oil change too.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Do you have a flashing or solid check engine light?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    no cel has come at all. when i apply enough gas i dont hear any sort of hiss sound resulting from a boost leak. It just seems like something bad will happen if I press too hard. I had an engine blow on me about a year ago in a diff audi because of a leaking head gasket that allowed coolant to seep into the cylinders so im just paranoid as well.
