Results 1 to 24 of 24
    Registered Member One Ring brandonp's Avatar
    May 28 2008
    CA
    Installed some BKR7E-11 Spark plugs... Power loss?
    I installed these plugs a little while ago, gapped them properly and whatnot, and now my butt dyno is telling me I am not pulling as hard.
    What could be causing this? Would it be obvious to me if I was constantly misfiring? I though it would me.
    Maybe I am imagining it all.
    Help.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Installed some BKR7E-11 Spark plugs... Power loss?
    the s11 at the end means its the longer threaded version... you need the bkr7e NOT s11
    May 28 2008
    CA
    f*** me eh
    Oct 27 2007
    In the lab
    hey its not so bad... just get the right plugs for less than 10 bucks at NAPA and spend the 15 mins puttin em in... no biggie, as long as they didnt thread past the deck
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    how often do you guys change your plugs?
    I know its been discussed, just curious.
    I use bkre6 and I change them every 10K?
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Oct 27 2007
    In the lab
    i change my bkr7e's in my golf every 5k-10k, depending on how the gap and center electrode are...
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    basically about the same here.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I thought the BKR7e's should be changed like every 3k?
    I was about to buy new ones, should I? I have ran them for 3k, should I recheck the gap (what should it be at .32?)
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 27 2007
    In the lab
    Quote Originally Posted by biketsai View Post
    i set my gap to .028, as long as its not misfiring your good
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I change mine every 1/4 mile.
    Apr 22 2007
    Riverbank, Ca
    I've had mine in for about 30k miles.. I inspect them every oil change though...
    NKG's... the 4 point tip ones..
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    damn dude, dont use them 40 dollar plugs too?
    crazyness..
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jul 07 2004
    socal
    Quote Originally Posted by maxspeed View Post
    crazyness..
    lol, I was just kidding. My last run at the track a few weeks ago was on the same plugs that were still in the car from when I ran back in Sept last year, someone even told me they looked fouled when trying to figure out why my oil was foaming up. I run the bosch F6DTC plugs which are $4 each.
    Dec 05 2007
    I read that the Bosch F6DTC can run up to 25k before needing to change. Hey Mike, is there is a certain franchise that carry those plugs. I had to order mine and Autozone and Autoparts does not carry them.
    Jul 07 2004
    socal
    No. You can get them from 034, Eurocode or if your on the east coast RockAuto. I was looking into buying a case of them at one point, still need to since I always need spares.
    97 A4 2.0TQM
    Rochester, NY
    Aren't the -11's the ones with the .044 gap?
    May 28 2008
    CA
    Well I regapped... They were at around .035ish before gapping.
    So this could be why I am experiencing less power? The gas isn't combusting properly because the plug is seated too deep into the cylinder because the threads are too long?
    Oct 27 2007
    In the lab
    just get the right plugs! they are less than 10 buck a set lol... gap em at .028 (the NEW plugs) and see what you got
    Dec 14 2006
    Halifax, NS, Canada
    what do people think of F5DPOR?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Registered Member Two Rings 1.8G's Avatar
    Jul 09 2005
    99 1.8t, stage III
    Sacramento
    I run bkr6e on my gtrs, gapped at .028. I think that its recommended that you change copper plugs every ~5k, so i just do it with oil changes (failing plugs really are really noticable my gtrs). Also, I hear that they will never seal up as tight if you remove them to inspect them, and put them back in. I'm not entirely sure if that is true, anybody else ever hear the same thing? Also, I torque them to 22.5 psi.
    4 turbos, 2 clutches, 1 addiction and 0 money.
    Oct 27 2007
    In the lab
    Quote Originally Posted by 1.8G View Post
    eh, i pull the ones outta my audi regularly and re-install them... no problems here, and i dont use a torque wrench
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    i used to change my bkr7e w/ every oil change, but i have been running these same ones for almost ~10k and no misfire problem.
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Oct 27 2007
    In the lab
    Quote Originally Posted by 20vpower View Post
    same here, im at 10k on this set and my golfs fine... powers a lil choppy before it warms up (even at part throttle) but other than that theres no ill effects
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Brandonp, Why are you using 7RE's? What are you mods? I've personally had bad luck with 7RE's. I've had better luck 6RE's.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
