Results 1 to 19 of 19
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Best Oil and Oil Filter?
    What is the best Oil and Oil filter to use in our cars (1.8T of course ) and where should i get them?
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: Best Oil and Oil Filter?
    Make that Spark Plugs too. I plan to go 1+ in the near future if that makes a difference.
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Dec 25 2004
    Earth
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Talk about digging up and continuing to beat the long dead horse.
    The search function is free, and it's your friend!
    Not to dispute MikTip, because his contributions to the forums/communities are many, and he knows a hell of a lot... but I respectfully disagree (except for the filters... go large OEM).
    Down to brass tacks here...
    Check this thread for a good introduction on what kind of oil to run and why:
    Clicky click
    Then, read this thread I posted with data sheets on technical info on the best oils and make the decision for yourself:
    Clicky click
    After that, read this write up at AudiGeeks for the straight dope on spark plugs:
    Clicky click
    That will help further your edification.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Quote Originally Posted by Tactic12 View Post
    I know, I know. I usually do, but tonight I'm feeling super lazy, which you will see by my following question. I really don't want to read all those separate threads on oil, filters, and plugs, could you just tell me which is the best for all three categories? Thanks!
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Jun 28 2007
    Edmonton, AB
    Ugh... weak.
    -- ELF Excellium LDX or DiD / Total Quartz Energy9000
    -- OEM large filter
    -- NGK BKR6E or if you're chipped NGK BKR7E and be sure to change these (because they're copper) every oil change.
    I just don't understand how you could take the time to post, then read replies and post again saying you're too lazy. Talk about doing things twice... what a roundabout process.
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    -- OEM large filter
    yup, on the total quartz energy 9000 5-40!!!
    OE big filter, mann, or mahle.
    and those are the plugs i'd run too!!!!
    - Benny
    Dec 03 2005
    2 pedals 1FG
    connecticut
    OEM filters: http://germanfilters.com
    I buy boxes of 10 at a time.
    -Doug
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    I'd really like to do this too, but AoA says for the 80k sludge warranty I should show the purchase of oil and filter at the time of each change, otherwise it won't be easy to prove that the change was done at the correct time/mileage. But even individually, how would they be sure I still changed it on time?
    What complicates this is that I can't find any of the preferred/approved oils locally.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Jun 28 2007
    Edmonton, AB
    Quote Originally Posted by B6 Dude View Post
    Wow, I couldn't find a dealer locater online... you must be in the boonies! j/k
    Try pm'ing Shawn (A4ringedONE8T) and see if he'll ship you some from his shop at a good rate, otherwise, worldimpex is a great source with good prices.
    Hope that helps!
    May 31 2008
    Palm Beach, FL
    Well, I should've said "non-dealer" source. Especially my local dealer who not only sells every part at full list price, but they're idiots (take my word for this). Next closest dealer is ~40 miles away. World Impex is good, and I also usually buy from germanautoparts.com .
    Audios,
    -Neil.
    Buncha motorcycles
    Memphis, TN
    thats what i was thinking too... you could search and instantly have your answer or you could take the time to write a post, post it, wait for replies, then rebuttle them
    for your average person, OEM stuff is fine.. mobil 1 0 40w even though its not technically a full syn anymore... also if u are hard up for a filter, get the mobil 1 M-301 filter from autozone or wherever, its the same size as OEM
    APR Stage 2/AWE Intake
    Dec 25 2004
    Earth
    Ugh... weak.
    -- OEM large filter
    I buy Mobil 1, because its readily available on local store shelves! ELF is not...
    Total Quartz is $11 a bottle....
    You change your sparkplugs with every oil change?
    Own a torque wrench?
    Run those plugs too many times in & out of aluminum heads "untorqued", and you run a much greater risk of stripping the sparkplug threads.
    Jun 28 2007
    Edmonton, AB
    Quote Originally Posted by MikTip View Post
    I do have a torque wrench, actually. I put it down to its lowest setting of 20 lb-ft. If it's not on hand I just go 1/4 turn past snug.
    ELF/Total is rather easy for me to find now that I know where to get it. It just took some doing (through two oil changes of OEM Castrol garbage).
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Tactic12, I plan to go one plus relatively soon, hopefully before my next oil change. Would you suggest I get the BKR7E's now, or wait until my next oil change after i get chipped?
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Also, where and how much?
    And to retort to all the comments about searching and what not. I've already apologized for not doing it, what more do you want from me? lol. I feel i contribute enough to the forums to repost every once in a blue moon.
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    I think I use Valvoline 5w-30.
    Seems to work for me.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Dec 06 2007
    Lubro Molly!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    How much torque on the oil drain plug?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
