Results 1 to 26 of 26
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    upgraded fuel pumps?
    What are people dropping into their B6's when the time comes to upgrade the fuel pump?
    I was looking at the Bosch 044 Motorsport pump:
    http://www.034motorsport.com/product...roducts_id=347
    Cheers,
    boy412
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Dec 25 2004
    Earth
    Re: upgraded fuel pumps?
    Why?
    Your fuel pressure regulator knocks the pressure back down to levels your TT injectors are a custom to running at...
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    AFAIK no one has needed to upgrade the pump on a B6 yet.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 29 2005
    10speed
    San Francisco, CA
    this is true
    - Clint
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by dirtybrd View Post
    Looking @ my records I have personally sold 6 044 fuel pumps to B6 users.God knows what Javad and the others have sold....
    Not every single BT B6 is on Audizine.Infact one is getting 2.2 T3T67 treatment now
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    bosch 044 fuel pump drops wright in and takes less than 20 min to install. if i had to rate the install on a scale of 1 to 10 it is a 3.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by MikTip View Post
    Why?
    I was thinking more in terms of reliability than anything else. I think I may have had another VDO pump go bad on me and was thinking I'd try something else if need be.
    ~Eric
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by Issam@034 View Post
    we'll make that 7 soon
    btw, i need a turbo
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I am installing my 044 pump next week to see if the hesitation I am getting at higher boost is a fueling issue or not.
    Dec 25 2004
    Earth
    Quote Originally Posted by boy412 View Post
    Do you run your gas tank to "E" before fill-up?
    The fuel pump uses the gasoline in your tank for cooling.
    Run the tank on "E" too often, will cause problems for the plastic pumps....
    The fuel pumps in our cars will gradually lose efficiency over the years, as they wear, and their pressure output will slowly drop...
    If your FP is a few years old, a new one will restore the systems efficiency, back to where its suppose to be.
    Also change your fuel filter before installing a new pump!!! It traps all the trash the fuel pump gives off.
    Dec 25 2004
    Earth
    Quote Originally Posted by 102487thedude View Post
    The 044 pump looks quite different from the OE pump....
    Did we forget to mention some "oh by the way..." for installing the 044 pump?
    Good posts to read-
    http://www.audizine.com/forum/showthread.php?t=142299
    http://www.audizine.com/forum/showthread.php?t=142969
    Apr 06 2007
    O34 motorsport sells the modified basket that drops right in whitch is what i did and it works great.
    visit,
    Dec 25 2004
    Earth
    What about the electrical connectors, and the top outlet hose?
    Its 90 degree's on the OEM and straight on the 044...
    Still not telling us all the mods required to make the 044 run on a B6
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    it will not fit this one is a direct drop in...
    http://www.034motorsport.com/product...ducts_id=13869
    Dec 25 2004
    Earth
    Quote Originally Posted by outsider6661 View Post
    Looks like 034 has "adapted" the 044 into the OEM basket, to remove all the DIY guesswork and headaches.
    Thanks outsider6661!
    Jun 11 2005
    Vancouver, BC
    You don't need to modify the basket to make it work.
    There is a different Bosch pump that drops right into the basket. I'll have to go dig up the part number for you.
    Apr 06 2007
    the only thing you have to do with the pump from 034 motorsport is snip the old electric connetions from the old fuel pump and crimp on the new ones that come with the 034fuel pump and drop it in to the tank with the basket it comes with. and last just connect the new hose that comes with the fuel pump.
    visit,
    Jul 15 2007
    Mount Rainier, MD
    Thanks for all the input everyone...
    boy412
    ~Eric
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Note that the new hose that came with the fuel pump disintegrated on me after about 4-5 months. Fuel pump made lots of noise and car barely revved to 3K rpms. After the hose was replaced the problem was solved.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    A lil note to everyone the yellow wire is ground and the black in the power. Ask me how i know. Anyone know where to get the tool to remove the basket. I have to remove my pump again because it seems like the guy that installed mine left a harness unplugged at the bottom of the pump and my car is enternally on "empty".
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Apr 06 2007
    you dont need the tool just grab the basket and twist. and then pull up and it will come rightup.
    visit,
    Apr 16 2007
    Queens
    Do i twist clockwise or counterclockwise? and i shouldnt have to twist it more than 15Deg correct?
    2003 A4 1.8TQM
    Senior Member Three Rings jokas's Avatar
    Jun 11 2004
    2003 Audi A4 1.8T Quattro
    North Jersey
    how often do you need to change your fuel pump??
    Dec 25 2004
    Earth
    Quote Originally Posted by jokas View Post
    There's no real "need" to change the pump, unless is shows signs of failure, or fails.
    The pump is an electric motor. It wears over time.
    The only real test is to check the pumps pressure output. Too low pressure, change it.
    Jun 11 2004
    North Jersey
    i see, thanks for the info. my fuel pump died last year and was covered under factory recall. too bad they didn't let me know about the recall until i was on the highway and the car seized up and died in the middle of the highway...hope that never happens to me again...
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    people are getting the 044 to work in their cars? I tried a while back and no way will it fit. I did however end up using another Bosch high flow pump that is similar to the 044 but without the nut like thing on the end. I worked with scott at USRT and 034 to get the right fuel pump listed for our cars
    Some fast things and some slow things
    ~Josh~
