    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    any thoughts on these inlets and fmic pipes
    just wondering anyone using these here? The fmic piping allows the fogs still which i like.
    http://www.mrctuning.com/fmic.php
    http://www.mrctuning.com/intakek04.php
    Registered Member Two Rings
    Mar 23 2008
    seattle
    Re: any thoughts on these inlets and fmic pipes
    nice, not sure id spend that much more to use fog's. since the exchange rate for euro's is almost double US currency....looks like good quality. Also I wonder if you have to loose the lower mesh. Ive seen ppl with the ebay kits still using the mesh just not the fogs....
    Oct 29 2005
    10speed
    San Francisco, CA
    it says lower grills are removed
    - Clint
    Active Member Four Rings
    Dec 11 2006
    Boston
    mrc is just an eBay setup that has grilles that are pre-made to fit somewhat good.
    same thing with JHM
    just an overpriced ebay setup
    Stage 3+ RS6's
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by deb38 View Post
    same thing with JHM
    meh those pipes look real nice tho Derek
    - Clint
