Thread: burning oil
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    burning oil
    just installed a gpop rebuilt k03 with k04 upgrade and VMR test pipe. I'm getting a loud noise at startup, kinda sounds like a sqweaky fan belt, but it's coming from the turbo. I've also noticed a few puffs of blue smoke after letting the car sit and ideal.
    Bad turbo or maybe?
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: burning oil
    sounds like it
    - Clint
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: burning oil
    Running lean because of the TP and no adjustment with the chip tune?
    IDK, it's just a guess...
    How's the rebuilt turbo though? I've been considering one myself so I wonder what your impressions are.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    Re: burning oil
    did the ko3 fail, and did you replace the oil feed and drain lines to the turbo? When i worked at nissan i had a passat that came in on trade that has a bad turbo and they had me replace it, the intercooler was full of oil was such a mess.
    Feb 07 2006
    ouellette
    Re: burning oil
    No we didn't replace the either of the oil lines. Should these be replaced, or can I take them off and clean them out? I'm wondering if the turbo just isn't getting enough oil flow when the car starts.
    Car doesn't sound like it's running lean, no pinging noise. Haven't taken the car past 4K rpms since the software hasn't been tuned for the upgrade yet. That should be happening monday or tuesday.
