Results 1 to 9 of 9
    Oct 29 2005
    10speed
    San Francisco, CA
    Has anyone done rods on a B7 yet?
    Just wondering... The sooner people start building these 2.0ts, the sooner the fun begins
    - Clint
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: Has anyone done rods on a B7 yet?
    I'm really thinking about it
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by HID View Post
    well, Im trying to get my buddy to man up and do them. We will see if he finally gives in soon or not. Seriously, I remember when B6ers never thought about doing even rods, but now 2.0 setups are getting common. The sooner the B7s get into it the sooner the turbo kits will come
    - Clint
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Im looking to do rods in the somewhat near future! Here is a company that has them if you are planning to use the stock piston.
    http://www.bshspeedshop.com/store/pr...3&cat=0&page=1
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by viziers View Post
    vizi
    not bad at all, I wonder what the limit is for the stock pistons, I know on most 1.8Ts, it was 500+hp, plenty for most BTs. I see ATP also has a manifold for the transverse FSI guys, Im sure a longitudinal mani is comming soon
    - Clint
    Jan 27 2007
    NC
    My understanding is that they can handle up to 450-500 hp but i could be wrong and i might just replace them as well. If you find out differently id be interested to know.
    vizi
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Need to put in set of these
    -Kris
    Jan 27 2007
    NC
    Quote Originally Posted by IceMole View Post
    That pic looks like it was a pic of jc@douglas 2.0t fsi build on fourtitude and the pistons are JE pistons right?
    vizi
    Veteran Member Four Rings John1.8T's Avatar
    Jun 08 2005
    2005.5 Brilliant Black Audi A4 2.0T Quattro 6spd.
    Waterloo, Iowa
    Anything past 350whp and the internals are going to have to be built up.
