Results 1 to 14 of 14
    Active Member Two Rings rvincent's Avatar
    Jun 11 2008
    '99 A4 2.8, '98 Jetta
    honolulu, hawaii
    service lights coming on
    i pot the car on reverse and in big bold letters it says "OK! SERVICE" and then i put it on drive and half of the screen turns off. Has anyone else had this problem or does anyone know whats wrong with the car? Thanks.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: service lights coming on
    does it say ok and service at the same time?
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    i don't think it can say ok and service at the same time, because if it needed service, it wouldn't say ok
    {99.5 Avant}
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Just means you need an oil change...
    ΜΟΛΩΝ ΛΑΒΕ
    Jun 11 2008
    honolulu, hawaii
    it says OK and SERVICE at the same time and i just got an oil change
    Dec 05 2007
    Is it just the service interval warning light? It comes on every 10k miles I think. You just need to reset it.
    97-99 Service Interval Light Reset DIY
    2001 Service Light Interval Reset DIY
    And for some odd reason, they don't say anything for 2000
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    ^Where is a list of what the Service interval codes mean? Mine is flashing "1n 1"
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Dec 05 2007
    Service Interval Code? I have no idea what that is. Maybe another can chimme in to help. If your cluster is giving you a warning like that, maybe the owner's manual could tell you what it is. But I don't know.
    Jun 11 2008
    honolulu, hawaii
    umm now it just says "OK SERVICE IN 10,000 MILES" and if i put the car in reverse or drive the screen goes blank how do i fix that?
    Dec 05 2007
    If you followed the DIY, there should be no issue.
    Sep 23 2007
    doesnt that reset only work for the oil change doesnt a technicain have to reset the service light?
    Jun 11 2008
    honolulu, hawaii
    yeah man i tried it numerous times but the same thing keeps showing u[
    Mar 04 2007
    nothing
    nowhere
    Try hitting the button on the bottom of the wiper stalk...
    ΜΟΛΩΝ ΛΑΒΕ
    Jun 11 2008
    honolulu, hawaii
    wow.. that actually worked... haha thanks man
