Results 1 to 6 of 6
    Dec 12 2006
    Charlotte,NC
    Noisey Fuel pump?
    Well it sounds like the fuel pump you can hear the hummy through out the whole car. Is this a common problem with these cars. Its my wifes 04 A4 1.8t frontrak.. Are there updated fuel pumps, Fuel filter was changed 4k miles ago i bought it used with 50k on it.
    MK4 GTi 1.8T converted to AWD
    New 1/8th mile 7.36@102mph-27psi 93 octane, no meth
    New build times 23psi pump 11.9@126mph-96mph in the 1/8th
    04' A4 1.8t frontrak converted to quattro, was RWD for a lil now its quattro finally
    2011 JSW Tdi 6speed manual
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    Re: Noisey Fuel pump?
    lots of fuel pump recalls.
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Dec 12 2006
    Charlotte,NC
    Quote Originally Posted by scorneil View Post
    How do i find out my car falls under this..
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    is it like a whining noise coming from under the right rear passenger seat. If so it very well could be just your fuel filter. I had a similar problem a month or so ago and it turned out to be the filter. took no time to fix at all real easy. check that first before you buy a new fuel pump. good luck
    WTB K04 turbo ASAP
    http://etektuning.com
    Dec 12 2006
    Charlotte,NC
    Quote Originally Posted by evola4 View Post
    replaced it 3-4k miles ago. The whinning went away at first but today it was much louder then normal. Car drives fine for right now. I think im just order a new one cause on wensday im driving to washington DC and dont want to tow it back.
    Oct 27 2007
    call your local dealer or AOA
    Quote Originally Posted by O2VW1.8T View Post
