Results 1 to 4 of 4
    Oct 22 2006
    Should EVAP purge valve go click on tests?
    When i run the system output test via VAGCOM am i suppose to hear clicking on my purge valve? if so there is no clicking just a air sound, i replaced the purge valve recently so why is there no clicking? could it be a fuse?
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: EVAP purge valve question?
    Quote Originally Posted by karmad View Post
    When i run the system output test via VAGCOM am i suppose to hear clicking on my purge vavle? if so there is no clicking just a air sound, i replaced the purge valve recently so why is there no clicking? could it be a fuse?
    are you getting a code for incorrect flow?
    Oct 22 2006
    Quote Originally Posted by AudiRacerS4 View Post
    yes i am
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Re: Should EVAP purge valve go click on tests?
    Mine clicks when tested using VAG-COM. Check to see if there is 12 volts at the connector. If not then look for a fuse or possibily a short. Measure the resistance for the purge valve. If there is none then consider the replacement bad also.
    2014 A4Q Red w/ black optic black interior
