Results 1 to 12 of 12
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    I need a list of tools, write-ups, and etc.
    Ok guys. I need to make this something I can print out if possible. I'm doin the TB on my Aunt's A4 (05' 1.8tqTIP, Amulet Red, loaded out, 60k miles) and I want things to go as smoothly as possible.
    Can you help me list ALL the tools i'll need to do a timing belt? Not necessarily stuff like 10mm socket, but more along the lines of special stuff. Torx bits, special alignment stuff, etc.
    I'm more than certain I could search and find the write-up, but if someone could just post up a link, I would appreciate it alot.
    Thanks guys.
    Wish me luck.....
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Dec 06 2007
    Re: I need a list of tools, write-ups, and etc.
    -Kirk
    BetaAlphaTau Member #58
    Nov 11 2006
    North Webster, IN
    I appreciate you being such a post whore. LOL!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Just a side note that wasn't in the write up is that you should crank the engine over to find the spot where it isn't on the cam and wants to move as soon as you remove the belt. Also a tip from Old Guy is to mark the belt on the car with marks on the crank wheel and cam wheel then lay new belt on old belt and make same marks... can't go wrong with this tip... GL
    Oct 29 2005
    10speed
    San Francisco, CA
    this is pretty easy if you make sure you do a few checks first
    O and make sure your in neutral with the plugs out when you turn the engine over
    - Clint
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    when did you guys change your timing belt (miles/years)
    also did you change(mod) anything else while you were in there
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Quote Originally Posted by t0mt0m View Post
    71k miles on an '04 a little over a year ago... no mods as the pistons hi-fived the heads so I got new heads at the stealership and that was my two-year mod budget.
    Might as well go with a stg 1 reflash, DV, and TIP (unless you're there already)... hard to go wrong there. And if you're ambitious, flush and upgrade all of the car's fluids (tranny, engine oil, diffs, brakes, coolant). That should hold you off until you've taken care of the suspension and brakes, then are ready for the BT or BAT plunge.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    It'll be real easy to do snub mount, DV, TIP, Throttle body hose, and FMIC while you have the front end off. I did snub and changed my DV spring for GIAC FX. The stuff mentioned above is a good idea also but not necessary if you have been doing your normal fluid changes.
    Nov 11 2006
    North Webster, IN
    Pondside, I must ask.
    Can we get some pics of your gorgeous Goodwood Green A4?!
    I love that green color.
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by pondside36 View Post
    good advice, i did my FMIC and power steering cooler while i was doing the TB too
    APR Stage 2/AWE Intake
    Nov 11 2006
    North Webster, IN
    Since this is for my aunt, I'll prolly just be doing the maintenance items. If it were my car....well....to hell with my car. 110K miles....original belt AND I drive it like a pissed off teenager.
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    original belt @ 110k miles, umm maybe you should be replacing your belt at the same time, your driving on borrowed time bud.
