Results 1 to 10 of 10
Thread: I Have a Dream
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Lightbulb I Have a Dream
    I dont want this thread to turn into an opinion thread about whether you like it or not but I do want your insight on how it can be done.
    I am really fascinated by the new MBC that has the extension cable to turn the boost up in the car. I thought about where it could mount and be badass. So the only spot I thought it would be cool is where the cig lighter pops out. I wanna make a custom bracket and mount it through that and somehow wire it through the console. So whenever I wanna adjust the boost, I can just pop that thing open.
    Ideas?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Re: I Have a Dream
    if done properly should look pretty clean and go with the car nicely.
    2004 Subaru Impreza WRX
    Aspen White
    Senior Member Two Rings isleepsober's Avatar
    Dec 24 2007
    RIP 98 A4 1.8T Quattro
    PA
    Re: I Have a Dream
    dude try it out let us know how it works.
    EX- BetaAlphaTau member #38
    Soon to be Stage II 01 Allroad 2.7t 6mt
    Dec 05 2007
    Re: I Have a Dream
    You basically are going to delete the cigarette lighter and replace it with a cusom mount for the mbc. What you may be able to do is take out the cigarette lighter assembly and get a custom plastic mold. Then maybe dremel it to fit perfectly OEM with the mbc. But say bye bye to cigarette lighter as that would more than likely get destroyed in molding process. Just a thought. Anyways, if you plan on it please update. That would be cool.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: I Have a Dream
    i think it would be dope! i smoke and i don't even use the cigarette lighter. so who cares about loosing it. do it
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jun 04 2007
    Austin/DFW, TX
    Re: I Have a Dream
    yea my friends say if I really need a plug I can buy some adapter that just hooks right up to a 12v connection.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    Re: I Have a Dream
    why not get a ebc and just save yourself the trouble
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: I Have a Dream
    Quote Originally Posted by aytheory View Post
    2nd if you want small and clean, with only boost control do a Profec-B or you can do gear and rpm dependent boost with say the AVC-r.
    Jun 04 2007
    Austin/DFW, TX
    Re: I Have a Dream
    I know I should be going with the EBC, but this seems like it will work for now and I think it is a pretty cool idea.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: I Have a Dream
    I have been wanting to put an engine start button in that same spot but i'm not sure how to go about doing it.
    {99.5 Avant}
