Results 1 to 9 of 9
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    windshield wipers bouncing on the glass making noise?
    I just upgraded to the OEM aero blades with arms from the dealer and they tend to bump on the glass when there is a little bit of water on the windshield. The bumping goes away when I use the washer fluid but then comes back when the washer fluid goes away. They are great wipers but this bumping has to stop. I DO NOT mean they bump when there is NO water on the windshield but when it is drizzling.
    I use rainX and I was thinking that may affect the wipers causing them to stick a little bit?
    Anybody else have this problem? How did you fix it?
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Re: windshield wipers bouncing on the glass making noise?
    i had a similar problem but i think it was because my blades were old. I replaced the blades with Bosch Aero Twins and havent had a problem since. I also stopped using rainX after i got the new blades.
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    I would stop using the RainX...it is horrible for your windshield and wipers!!!
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    If you're using RainX, it's causing the liquid to run down & bead faster than the blades so you're just rubbing on "dry" glass.
    Mind you, I like RainX; I don't need to use my wipers nearly as much when it's applied.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    put more water in the reservoir will mostly solve your problem. lots of ppl change their blades, but it keeping coming back.
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    2004 A4
    Central Jersey
    Quote Originally Posted by WiZZLa View Post
    This is the answer I was looking for.... but how could I remove the rainX From my windshield or should I just clean it with something acid based windshield cleaner?
    I definitely could see the water beading and the wipers are cleaning off SO much water that there is no more water to clean off once it has already made its first pass....
    Jul 10 2007
    trunk
    Quote Originally Posted by 3.0L AUDI A4 View Post
    I've read that lighter fluid or windshield/glass cleaner would work.
    Stage 0 minus - .5
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    Quote Originally Posted by 04b6sport View Post
    how exactly is rainX bad for your windshield??
    i use it with every wash and hardly ever even need my wipers, like once a month maybe.
    Senior Member Two Rings seattlematt's Avatar
    Oct 10 2009
    1981 Fiat Spider, Sprinter, e46 vert
    I am having the EXACT same problem. I am starting to be convinced that these Aero blades from ECS are just bad quality.
