Results 1 to 2 of 2
    Dec 17 2007
    MI
    Please Help Me!!!!!!!
    Good morning gents and gals. I have a couple of issues I am trying to figure out.
    1st, I changed my coolant temp sensor and my oil temp sensor is all over the place. Does the oil temp gauge and temp gauge have anything in common? Sometimes it will surpass 250 degrees. What's up with that?
    2nd. I have serios turbo lag. I can hear my turbo, but I am not getting any boost. Does someone have a diagram to ensure I have my hoses connect correctly? I have an ATW engine. I changed my hoses and I could have sworn I had them connected properly. As always, thanks for your help.
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Please Help Me!!!!!!!
    IIRC, the only thing those gauges share in common is the data interface to the instrument panel from the engine module.
    Disconnect sensors one at a time and see what the gauges do to confirm your suspicion. Clear codes if any after the exercise.
    #2 someone more familiar with the ATW might be along.....
