    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    UPDATE: DBW gas pedal to Tilton race pedal conversion (sort of)...
    Let’s start with a regular B6 A4 DBW gas pedal with its potentiometer.
    Not to get into any trouble running the car because it is a BDW car we decided on a mechanical way to activate the DBW pedal by the Tilton race pedal. Here we cut off part of the OEM gas pedal.
    As you can see the Tilton gas pedal comes with a rod to activate a regular type mechanical throttle body.
    We took that rod and shorten it to fit our needs. We also “shaved” some metal (more like the paint coating) off the rod so that a rod end could be slipped over it.
    Rod end used in the new assembly. Two of these will be required.
    Rod end installed over the Tilton gas pedal rod.
    Rod installed (minus the rod end) onto the Tilton gas pedal.
    Now we also needed to do the same sort of installation on the OEM gas pedal so we drilled through the plastic OEM pedal installed a proper length bolt and slipped the other rod end onto it.
    The two gas pedals lined up in front of each other. The Tilton is somewhat offset to the left from the OEM pedal when looking at it from the driver’s seating position.
    To link the two pedals together via their respective rod ends we used a hollow tube which was treaded at both ends to accept the rod ends.
    Finally here are the two pedals hooked up together with our home made link. I’m glad to report it worked flawlessly during two days of tracking.
    Over all shot of the completed Tilton pedal assembly including some “anti-slip” tape used where the feet do all their working.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: UPDATE: DBW gas pedal to Tilton race pedal conversion (sort of)...
    nice
    - Clint
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    I must say, you have the strangest and most interesting "mod" posts. Werd to uniqueness.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Wow... lookin' very professional..
    Dec 06 2007
    thats not gonna be comfortable to use on the street lol! but for heel and toe it'll work like a charm!
    -Kirk
    BetaAlphaTau Member #58
