Results 1 to 8 of 8
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Finally Installed
    Well I finally had time to install the grill i painted the other week. I also installed actual yellow fog lights and the ECS snub mount. I need to take off the yellow lamin-x fog covers. The snub mount is really noticable, well to me. The shifting is much more calm. here are some pics with the new grill, I also picked up a black filler plate! I'm currently using the matching one becuase the black one needs some work! which one should i use on the regular basis?
    or
    Pretty sure the old grill is for sale!!!
    The usual things!!
    Resistor Install
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: Finally Installed
    i think the color match looks better, would you try colormatching the whole thing?
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    ^^^ Yeah I'm kinda digging the color matched one too.
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    So you swapped the standard bulbs in the fogs for yellow bulbs? If so, what type?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Feb 16 2008
    Oakdale, MN
    Yes, I got the ones from ECS, they are h11 and are called LIZA bulbs pure yellow: ECS seems they are on order right now!
    Thanks, I like the color matched one too, as for color matching the trim? is that what you are asking? if so i think i will leave it black for now! easy to do black and hard to color match. I had to have a shop do the filler plate and rear valence!
    The usual things!!
    Resistor Install
    Nov 12 2007
    Grand Junction, CO
    I really like the look of the black trim. How did you do that again?
    Feb 16 2008
    Oakdale, MN
    Thanks: For the trim I used:
    people yelled at me and told me to use plasti-dip. I have used plastidip on the window trim and it worked kinda. the plasti dip stuck to the tape and pealed it off with it. the paint doesn't do that so i might paint and screw plasti-dip for the trim!
    The usual things!!
    Resistor Install
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Looks good!!!
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
