Results 1 to 18 of 18
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Just installed track density transmission mount....vibrations from HELL!!
    Just finished installing the track density track density tranny mount and I am definetly taken aback.
    Shifts are nice and clean now. No more clunking inbetween gears, especially 3-4 which would always produce a nice clunking sound.....so
    But the vibrations were nothing what I had expected! I was assuming that I would get a slight shake JUST at idle, but the whole car is literally shaking when I give it throttle and take off. Ironically at idle, the vibrations are very minimal, but as soon as I start moving, I can hear my side mirror start to shake and all the coins in the holder just rattle like crazy!
    Before tightening all the bolts I did let the car run and idle. There is just no way that this mount is this harsh. It vibrates all the way through the powerband.
    Tomorrow, I am going to loosen everything and let it idle again, since the mount is a LITTLE uneven along the transmission crossmember, so I am hoping that, somehow, realigning it will atleast reduce the vibrations past idle.
    So, for those with the TRACK density tranny mount, are you experiencing bad vibrations as well? I know to expect some, but like I said, I was only anticipating vibrations at idle and not through the rest of the powerband.....
    -Sami-
    Buncha motorcycles
    Memphis, TN
    Re: Just installed track density transmission mount....vibrations from HELL!!
    post up, i was fixing to order but damn 034 went up on all their prices!
    APR Stage 2/AWE Intake
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Papachristou View Post
    did they? I remember when the engine mounts were like $45 a piece!
    - Clint
    Feb 19 2007
    Charleston, SC
    yea, there motor mounts are $95 a piece now....crazy!
    anyways....so no one has the track density mount here?
    -Sami-
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Crazy how? Have you noticed the change in Euro to USD exchange? It isn't like the parts are mass produced in this country seeing that they are made by a company that makes OEM parts for german cars. Its pretty simple to figure out if the costs go up to produce a part the retail price is going to do the same thing. They only went up a little more then 26%.
    BTW why would you put a track density mount on a daily driver?
    Feb 19 2007
    Charleston, SC
    Why not? I have owned alot other cars that were way worse than what my audi is feeling like now. Its just that I didnt expect it too be THIS bad Furthermore, there is no way that the mount can produce this many more vibrations.
    I have the mount back off right now (since it needed to be realigned, and this time around I will loosen the motor and snub mounts and let it all "idle" into position before tightening them all down.
    -Sami-
    Jul 07 2004
    socal
    I think there are plenty of other threads about the B6 tranny mount, might want to read those too. IIRC they said that the mount was slightly taller then the stock one which changes the angle of the transmission causing more vibrations and I think that was with the street density. Now this might not be a problem if your also running 034 engine mounts.
    If you think about it makes sense seeing that you said at idle it is ok but it is when you start moving that you get a bad vibration and thats when your driveshaft is spinning. You might want to measure the OEM mount vs 034 mount and the distance of the transmission when each one is installed.
    Feb 19 2007
    Charleston, SC
    Thanks Mike for the help. I indeed did read all those threads (that 5+ page one) and the DIY over on Audigeeks.
    For the record, the track density tranny mount is indeed about 1/8" taller than the stock OEM mount, therefore "unseating" the snub mount (I have the APR one). So all that was needed was to loosen the tranny mount again, loosen the snub mount, and let it all "idle" into place. Tightened it all down while the car was still idleing and it fixed it 100%. Obviously there are some extra vibrations from the solid mount, but only me as the driver would notice.
    So, I am MUCH happier with this mount now and it is definetly totally tolerable.
    -Sami-
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    034 sent me a track density tranny mount by mistake the first time. I ran it for about 4 days. My mechanic says the car sounded like a DTM car. Until I hit about 5K rpms all I heard were the rattles, vibration, transmission whine, gears, etc. Only after 5K rpms I was able to hear the engine/exhaust lol. A bit too hardcore for me.
    No problems with the street density mount that I've been running since August 2007.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by Tgr_Clw View Post
    Exactly, maybe yours was not seated correctly. Last night driving around sounded like I had straight-cut gears...the transmission whine was unbelievable. Sounded cool, but no thanks. But this morning after realigning the snub, trans mount, etc....no more whine from the tranny!
    -Sami-
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Is that safe to run them thought with all these vibrations??? Cause that might be a cool mod for some hardcore sound:)))
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Perhaps, but we tried seating the mount and adjusting the snub mount (unbolting literally everything basically), but it was still too much.
    Appearance: OEM+
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by aaaudiprotein View Post
    Not sure about safe or not, but it's simply too much for a DD imo.
    Appearance: OEM+
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    Double check your snub mount adjustment
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    Feb 19 2007
    Charleston, SC
    Just went through a long drive in traffic and it seems like a new array of sounds have popped up.
    The one thing I am aware of now is that since the transmission sits up about 1/8" higher, would that affect the driveshaft bearing? From a stop, I can hear (what sounds like) a creaking door, until about 10mph.
    Any ideas?
    -Sami-
    Jul 07 2004
    socal
    That is very good to hear.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Any ideas?
    Did you put the washer from the stock mount on the new one?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by dirtybrd View Post
    Are you reffering to that metal plate? If so, then NO, I did not transfer it to the 034 mount.
    EDIT** Are you talking about the piece in the guys hand?
    -Sami-
