Results 1 to 10 of 10
    Veteran Member Four Rings Hockenheim's Avatar
    Jul 09 2007
    Phoenix
    Question about RS4 parts in an S-Line B7
    1) Can you swap in the RS4 honeycomb foglight grills and main grill into an S-Line Bumper
    2) The RS4 has a little lip in the middle under the bumper, can this be installed on the S-Line bumper
    3) The RS4 has upgraded brakes with cross drilled rotors, can these be swapped into a B7?
    4) Can the the RS4's gas mileage be swapped into my 2.0T?..... JUST KIDDING!~
    Veteran Member Four Rings TDI's Avatar
    Nov 13 2006
    a4 avant B7
    Belgium
    Re: Question about RS4 parts in an S-Line B7
    [QUOTE=Hockenheim;2678054]1) Can you swap in the RS4 honeycomb foglight grills and main grill into an S-Line Bumper
    main grille--->yes=plug and play
    foglight=nope=shape is different
    -God show me the way..because the devil try's to break me down-
    Kanye West
    Established Member Two Rings STaSIS_2.0T's Avatar
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    You can also swap the aluminum trim from the rs4 grill and snap in the chrome trim from you're s-line grill. I did that, looks awesome and still matches the chrome window surround
    STaSIS/GIAC ECU | ITG ProFilter | EvolutionRacewerks SMIC's | STaSIS exhaust | STaSIS/Koni/Vogtland suspension | STaSIS/Alcon 355mm Mono4 brakes | Volk CE-28 19x8.5 | Toyo T1-R 265/30 | O.Z. Superturismo GT 18x8 | Dunlop Wintersport 3D 235/40 | JHM short shift kit | ECS snub | RS4 rear sway | RS4 pedals | S4 shift knob | RS4 grill w/s-line chrome surround | VMR vent boost gauge | 034 Intake Pipe | CoolBoxMod | Hardwired 8500 X50 w/"OEM" mute button |
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Technically answer is "yes" to all of those questions given you have the money (and the insanity).
    But from a practical standpoint: not any of those are a "direct fit".
    2006 Audi A4 2.0T Quattro 6MT S-line
    Nov 13 2006
    a4 avant B7
    Belgium
    maingrill is diret fit in s-line front bumper though
    Kanye West
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    Yep, the RS4 grill is a direct fit... but like all B7's... the only thing you have to do is remove the front bumper
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    and removing the front bumper is pretty easy, it sound hard but it isn't. i just did it tonight and took maybe 2 hours. for my first time. Just make sure you have thje right tols. i had to run to home depot!
    The usual things!!
    Resistor Install
    Registered Member Two Rings The Broker's Avatar
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    Are you guys serious 2 hours to remove the front bumper? It takes me less than 20 minutes it's like 16 bolts/screws and only 4 that are difficult to reach unless you use an extension for your ratchet. Try removing the rear bumper, now that's a bitch.
    Feb 16 2008
    Oakdale, MN
    well for my first time yes 2 hours! I had to go to home depot too for some tools!
    The usual things!!
    Resistor Install
    Established Member Two Rings prayforsnow247's Avatar
    Mar 24 2008
    '08 A4 2.0 SE
    stasis 2.0... do you have pics of rs4 grille with chrome trim?
    Let the mods begin
