Results 1 to 11 of 11
    Senior Member Two Rings cfujikawa's Avatar
    Feb 04 2008
    how to remove card holder?
    hey guys, i need your help. i'd like to run my ipod cables into my card holder tray. i've searched and found threads that point out how to remove the card tray in B6 A4's, but it looks to be a bit different from our B7's. i've removed my stereo, and the trim piece that goes above the console, but i can't seem to figure out how to get the card tray unit out.
    can anyone offer any words of wisdom?
    : 2017 Daytona Gray Pearl Q5 2.0T Premium Plus / Tech / Sport / 20" Rim Pkg :
    : 2007 Silver Acura TL Type-S :
    : 2013 VW Golf 4-Door TDI : *gone*
    : 2006 Quartz Gray A4 2.0T Quattro S-Line Tiptronic : *gone*
    DUH! an Audi
    los angeles, CA
    Re: how to remove card holder?
    search!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    jping,
    i had the same question, what you do is there is a umm cover above the tray..use a screw driver to pop that up.
    then when you see the tray, there is some tabs top and bottom, then you use the flat head to push the tabs and then pull forward.
    ill try to take pics.
    Feb 04 2008
    thanks for the tips Quattro, i'll try it out this week. if you have any pics, that would be great. much appreciated!
    Senior Member Two Rings Phantom2.0T's Avatar
    Mar 29 2008
    B7 Ti-Pack A4
    CA/MD
    Anyone done this? I have a 2007 A4 and I do not see any release tabs to pull the Card Tray/ Holder out. It looks like the space where the dead button occupies is joined to the card holder well. My card got jammed in the card holder and somehow slipped behind the tray. Would it be safe to say that my card is behind my radio, or is there a bottom to the card holder well which would prevent it from falling down into the radio wiring? If there is a bottom, how do I get the tray out!!!
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    You use 2 small screwdrivers to put the tabs that are on THE TOP of the carholder chassis that currently are engaged to the trim frame.
    If you look carefully you should find two small slots where the clips are. Here is a picture of my cupholder which should give you an idea of where they would be.
    More details on the cupholder mod are here: http://www.audizine.com/forum/showthread.php?t=195375
    So glad this was brought up I have wanted to do this for over a year! Also is there a way to move the card holder over to the Left Hand side? And the buttons to the right side? Wooo Hooo!
    KO
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    Quote Originally Posted by cfujikawa View Post
    what kind if ipod cables??? are you just running an AUX wire?? if so do you need to vag-com to get the aux to work??
    Feb 04 2008
    Quote Originally Posted by Bllzll View Post
    i'm using the DICE unit. it's nice because my 3rd gen nano fits perfect in the card slot. i ended up fishing the wire through the front, under the trim piece. i'll see if i can fish it through the back when i have more time.
    btw., winston, your profec install is awesome!
    Registered Member Two Rings jamesmi13's Avatar
    Nov 09 2007
    Audi A4 B7
    seattle
    I am using a Dice iPod connection, how do i get the track names to appear om the deck display
    Feb 04 2008
    Quote Originally Posted by jamesmi13 View Post
    unfortunately, you can't.
    Does anyone know how we can move the card holder to the left hand side? Spanks!
    EcoLuxuryDetail.com
