Results 1 to 8 of 8
    Feb 15 2007
    marimont
    a little time line of the new member
    Well finally getting it close to where I want it for now. Enjoy B)
    When I went to pick it up in Boston. Had to change the wheel bearing, spindle, and trailing arm before I could head home.
    She was in pretty ruff shape. Had to stop in Pa to pick up a new hood and OEM headlights. After I got it home the other spindle, wheel bearing, and trailing arm need replaced. Did all that and had it aligned. Then to find out next the rear calipers were seazed and the rotor was warped. Decided to replace them with B7 S4 rear rotors (300mm) and s4 rear calipers. Also went and put on A8 brakes up front (312mm). Also did s/s lines.
    That's the comparison of the stock (L) to the S4s ®.
    There's the 034 mounting brackets for the s4 calipers.
    The stock a4 calipers on the (L) and the s4 calipers on the ®
    Well since you have to have atleast 16" wheels for the rotor size. From the looks of it the rears need atleast 18s bc the caliper is almost touching the inside of the wheel. So I got some 18's for it. Oh and bought Ryans old S4 bumper.
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: a little time line of the new member
    what did the rear brake setup run you. i just got some a8's up front, and wanna do the rear s4.
    did you just buy the calipers from a junk yard and new rotors?
    just curious what everything ran you, and if thats the path you took.
    edit: oh and get on that clear corner mod..........car's shapin up and looking real good.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Aug 04 2007
    92 Jetta,2001 A4 2.8
    Cranston, RI/MA
    Looks good...i want to do the A8 and the S4 rears as boosted said
    am i the only one that likes the ambers?
    ~Bo
    92 Jetta- daily-slammed,TP...to much to list
    01 2.8- project
    Dec 05 2007
    Thats's clean
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Are the A8's 12.3 inches. I swear to Jesus the PO put on A8 rotors.
    Oct 30 2006
    B8 A4 Avant 6spd
    Nice, I didnt get to put mine on because 034 was selling them without the brake lines at first.. Had the car on the lift and inevitable happened.. Had to get standard S4 rotors to drive out.
    -18 718 GTS
    Veteran Member Three Rings brlukosk's Avatar
    Mar 21 2006
    St.C MN
    nice! i'd like to get some s4 rears
    Feb 15 2007
    marimont
    I got the calipers from a junkyard for 30 a piece and the rotors were 130 from purems. Got the brackets from 034 and used standered s/s lines with no probmes. You have to install the lines before you put the caliper on. It will BAIRLY clear. I know I need to clear the sides but, I'm getting a pioneer acv-d3, s4 rails, and s4 mirrors. I know they don't cost anything but, it's bc I'm lazy. lol.
