    Jan 17 2008
    louisville
    gauges going crazy
    soo, it started about 3 months ago to where my gas gauge doesn't read properly. When the tank is full, it seems to be accurate until about 1/2 tank. Then it will start going up or down and settle at a point. The point it settles at will vary. If i turn the car off and back on, it will read something different. It has gone to the extent to where I've ran out of gas when it says I have a 1/4 tank, and it will say its empty when I know I have like 4 gallons left. Well recently, all the gauges have started acting weird. When i turn the vehicle on, my tach needle will vibrate at 0 back and forth rapidly for 10 seconds then it will jump to the normal 800. all the other gauges remain at 0, and after ten seconds they go to their respective spots. besides the gas gauge, they all seem to function fine after this ten seconds.
    so, does anyone have any ideas? Is my cluster bad, or just a delayed relay?
    Registered Member Two Rings
    Mar 21 2008
    va
    Re: gauges going crazy
    Holy Crap!! This is the exact same problem with mine. Although the fuel sender fixed my fuel gauge, but my tach does the exact same thing!!
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    you have a bad fuel tank sending unit..
    Here is what you need
    http://www.ecstuning.com/stage/edpd/...bcategory=Fuel
    http://www.ecstuning.com/stage/edpd/...viewimage.html
    The stealership quoted me $252 for this same part...
    Jan 17 2008
    louisville
    thanks, I know that will fix the fuel, but the tach?
    Senior Member Two Rings 01 S4's Avatar
    Jul 23 2007
    01 S4, 87 yj trail rig
    long island NY
    how hard is it to change the sending unit ??
    01 S4 -James-
    2001.5, 6 speed
    Darintake, 710N, Samco TTB
    GIAC X
    clutchmasters stage 4 and LW flywheel
    K04's ...there screaming
    piggies, ssac catback
