Results 1 to 2 of 2
    Registered Member One Ring ForcedFed's Avatar
    Mar 13 2005
    1999 Honda Prelude Type SH, 2004 H2
    Murrieta, Ca
    Check Engine on and Gear Indicators Flashing
    I pulled the code and it says Trans Range Sensor. I cleared the code and it came back for a few minuets a few days later and hasnt returned. I googled it and found only a few things on it. Its located inside of the CVT Trans and is also known as the TCM. Have any of you had this issue or can shed some light on my situation. What am I looking at for repair costs? The cars drives fine and the fault code hasnt returned. Would a trans flush help out at all. The car is a 2005 a4 tip 1.8L. It hasnt had the fluid changed yet. Thanks for your help.
    Dec 22 2007
    04' A6 3.0 quattro
    orange county
    Re: Check Engine on and Gear Indicators Flashing
    sorry man your out of luck...(TCM) transmission control module is what you most likely need. i had the exact same problem with my 04 A6, went to the Audi dealer and they quoted my $2000 : ( but you can get it somewhere else if you shop for maybe 1200 to 1500. good luck
