Results 1 to 3 of 3
    Mar 24 2008
    chicago
    2000 A6 2.7T Nav Not Working Nothing Displayed on Info Display AirBag Light Wont Eras
    On my 00 A6 that I just got the Navigation system is not working and I also noticed I do not see anything being displayed on the Information Display.
    I also also the navigation drive in the trunk does not power up.
    Could this be a fuse? Or does it need to be reprogrammed with a vag com?
    Also I tried several times to erase my airbag light with a vag-com and it appears to erase but comes back right away. Any ideas on this?
    I ran a vag-com and I get this
    Chassis Type: 4B - Audi A6 C5
    Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
    Address 01: Engine
    Controller: 4B0 907 551 L
    Component: 2.7l V6/5VT G01 0004
    Coding: 06652
    Shop #: WSC 40104
    1 Fault Found:
    16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
    P0421 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans
    Controller: 4B0 927 156 BD
    Component: AG5 01V 2.7l5VT USA 3131
    Coding: 00002
    Shop #: WSC 00000
    No fault code found.
    Address 03: ABS Brakes
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D10
    Coding: 0273004284
    Shop #: BB 24334
    Address 08: Auto HVAC
    Controller:  รถ4B 082 004
    Coding: 00160
    Shop #: WSC 02325
    Note: Excessive Comm Errors
    Address 15: Airbags
    Controller: 4B0 959 655 F
    Component: Airbag Front+Kopf 1002
    Coding: 00306
    Shop #: WSC 02325
    1 Fault Found:
    00588 - Airbag Igniter: Driver Side (N95)
    32-00 - Resistance too High
    Address 16: Steering wheel
    Controller: 4B0 907 487 D
    Component: Lenkradelektronik D01
    Coding: 00103
    Shop #: WSC 65535
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    49-00 - No Communications
    Address 17: Instruments
    Controller: 4B0 920 980 M
    Component: C5-KOMBIINSTR. VDO D11
    Coding: 02264
    Shop #: WSC 00000
    2 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    01311 - Information Data Bus
    37-10 - Faulty - Intermittent
    Address 35: Centr. Locks
    Controller: 4B0 962 258 J
    Component: Central Lock/Alarm D33
    Coding: 15885
    Shop #: WSC 02325
    7 Faults Found:
    01371 - Alarm triggered by Door Contact Switch: Driver''''''''s Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00956 - Key 2
    09-10 - Adaptation Limit Surpassed - Intermittent
    01561 - Left Rear Door
    59-00 - Can''''''''t Unlock
    01574 - Alarm triggered by Door Contact Switch: Right Rear
    35-00 - -
    Address 36: Seat Mem. Drvr
    Controller: 4B0 959 760 A
    Component: Sitzmemory D05
    Address 45: Inter. Monitor
    Controller: 4B0 951 178 A
    Component: Innenraumueberw. D04
    Coding: 00101
    Shop #: WSC 02325
    1 Fault Found:
    01349 - Alarm via Theft Warning System: Front
    35-00 - -
    Address 55: Xenon Range
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00006
    Shop #: WSC 02325
    Address 56: Radio
    Controller: 4B0 035 195 A
    Component: Radio D00
    Coding: 00115
    Shop #: WSC 02325
    End
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Re: 2000 A6 2.7T Nav Not Working Nothing Displayed on Info Display AirBag Light Wont
    Did this all start happening at once. If so maybe a loose plug or smashed wiring harness?
    Mar 24 2008
    chicago
    i bought it like this
