Results 1 to 10 of 10
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Jacked the car up and now floor boards are fugly!
    I saw a spot right behind where the jack mount was put couldn't fit the jack stand underneath the car with the jack in that position so backed it up a little...noticed that the area raised up about an inch and now my floor boards are raised up to where the floor mates are now flush with the floor. Anybody done this and have a fix?
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: Jacked the car up and now floor boards are fugly!
    take some pictures
    B5 S4 AWE Stage 3 - sold
    May 23 2008
    Columbia, SC
    I know I need to vacuum! :) but you can see where the dirt is building up in the crevasse.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Its kind of hard to see what you are talking about in the pic. If it raised it up some from the jack. have you tried pounding it back down from the inside?
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    1) get a 12" scissor jack and a 4 foot long 4x4
    2) place the scissor jack on the floor and brace the top of the 4x4 against the roof
    3) extend the scissor jack to push the bulged floorboard back into place
    then...
    to get the bulge out of the roof of you car
    4) repeat the same process using the scissor jack and 4x4 braced off of the ceiling of your garage
    then...
    5) repair any cracked joists and replace the damgaged sheet rock
    Hope this helps...
    Oct 30 2006
    B8 A4 Avant 6spd
    Way to jack up the car by the floor boards and not solid points =/.
    -18 718 GTS
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    rubber mallet
    May 23 2008
    Columbia, SC
    It was like this when I bought it...the previous owner installed different floor mats so I'm thinking they just come up short and make the floor boards look like this. Can someone just feel there floor boards for me and let me know if this is normal? Thanks.
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    That's not normal. The material where the jack was placed is not strong and dented up. You have to remove the carpet from that area and hammer it down.
    Just take off the plastic cover on the door sills and pull the carpet back. Then get a 2x4 piece of wood that is just a foot long and place it over the bulge and hit the hammer on that and it should push it to a flatten.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    May 23 2008
    Columbia, SC
    Great...thanks man!
