Results 1 to 2 of 2
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Boost problems (Simple Question inside)
    Well, it seems that I can never get it right. When my car was bought, it turned out to have a broken wastegate actuator. Well that was fixed, but it seems that it wasn't fixed right. My dad and grandpa decided to do the job and it seems that they didn't pay attention to how the old actuator was afixed (didn't count the threads when tightening). I cannot boost past 11psi. New DV, just installed a TurboXS HP-BC so it's not the N75 either.
    My question is : Can I tighten the actuator without dropping the turbo? Also, do you guys know how much it needs to be adjusted to be in the normal location? Thanks
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Boost problems (Simple Question inside)
    You will have to pull the turbo out. You can use an air compressor set to 5psi to test the wg, then just tighten it so it just cracks open at that 5psi.
