Results 1 to 40 of 75
    Jan 01 2008
    Long Island NY
    2.0T Quattro Tiptronic Stage 2+ 0-60 Times
    Hey guys well after installing my boost gauge i figured i would do some hard launches and with my Vag Com get some 0-60 times. I did three runs. I seem to hold boost at around 15 pounds but spike at 19psi for about a second.
    1st Run: ESP Off Powerbrake to 3200 RPM Made 16psi of boost
    0-60 5.1
    2nd Run: ESP Off Powerbrake to 3000 RPM Made around 15psi of boost
    0-60 5.3
    3rd Run: ESP Off Powerbrake to 3300 RPM and Rev it to build some boost as i was Powerbraking, built up around 17psi of boost at Launch.
    0-60 4.9.
    I am absolutely thrilled right now. Just to make sure this was not some sort of fluke i hooked up the Vag Com to my moms Mercedes SUV and did a 0-60 dash. I got 6.9 seconds the exact time quoted by Mercedes so the Vag Com was not reading off. So i guess you can make an A4 Fast with a stock turbo. The temp outside was 69 Degrees but it just felt very cool and the car was pulling harder than normal. This was done with the spare tire in the trunk and me in the car (of course:) and im 240lbs.
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Re: 2.0T Quattro Tiptronic Stage 2+ 0-60 Times
    Impressive times if I do say so myself. Glad to know that it's possible to do some work with the Tip transmission.
    Also, thanks for the info!
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Sounds a little optimistic, but incredible if true! What was your tire pressure for these runs?
    And VAG-COM in a Mercedes? Really?
    Jan 01 2008
    Long Island NY
    Im actually planing on going with a Big Turbo kit. Either APR, AWE or Vast. As of right now im leaning towards AWE if they can keep the price at under 5k. All im going to do is upgrade my Torque Converter and try to get a custom tune done to the tranny to maybe shift faster and rev match 1st to 2nd gear. My goal with this car is to get it under 12.5 in the quarter and i think with the BT Kit i can do that.
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by johntesi View Post
    My tire pressure is 39PSI all around. Yes you can use a Vag Com in any car with an OBD II Port. You can select Generic OBD II under options. I also had about 25 miles left on the tank and have 93 octane.
    May 22 2008
    2013 Audi S4 IceSilver MMI/SD/DSG/AK
    Bay Area
    This is great info, has anyone else tried this for comparison? Also what is Stage 2+ defined as?
    Ice Silver S4 Black Int. Sport Diff DSG, B&O, Nav, Advanced Key
    Jan 17 2008
    Evolution X
    Texas
    You learn something new every day. You have an enviable budget, and great mod list! Keep on keepin' on.
    Jan 01 2008
    Long Island NY
    Im hoping to go to the track this month. Yes it will probably be 90 degrees out by my goal is to get a great 60' time and trap over 100mph. A 13.6 wouldn't hurt either but i think i might run in the high 13's low 14's due to the high temp. I will def. head down to the track October to see the difference nice 45 degree weather does.
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by yload View Post
    I have:
    APR Stage II Software with Test Pipe and FSI Programs 93 Octane
    AWE Full Exhaust
    Eurocode Test Pipe
    Carbonio CAI
    GReddy Front Mount Intercooler
    Forge DV
    APR High Performance FSI Pump.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    wow..3300rpm is pretty high with powerbrake. nice!
    TEAM|AXION
    May 22 2008
    Bay Area
    Have you done any Dyno's recently or have any idea/guess to what you are putting down?
    Jan 01 2008
    Long Island NY
    Thanks. Due to the fact i have bought most of my mods either used or during holiday sales im in the car for about 5k. Not as bad as you may think. It does help that im still in school and have the luxury of living at home so all my work money goes into my car (for now at least). Im taking advantage of living at home because i know in a couple of years when i need my own place i will not have the opportunity to do these mods.
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by speedydragon View Post
    What does a turbo timer due? I see it in your mod list. Sorry is this is a noob question.
    Jan 01 2008
    Long Island NY
    Im hoping for over 290 hp to the crank and over 310lbtq to the crank. I am thinking about getting the car dynoe'd at waterfest 14.
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Quote Originally Posted by Auditude2.0T View Post
    It allows the engine to idle for a preset amount of time after you've turned the ignition off/gotten out of the car to allow the turbo to cool. It's a neat toy, but really not necessary if you don't do any heavy boosting before you turn the car off.
    May 22 2008
    Bay Area
    Another noob question what is required to run the Stage II software? Do you need an upgraded intercooler? plus other items?
    Jan 01 2008
    Long Island NY
    You need to have an Exhaust and Testpipe. Then if you buy a high performance fuel pump you need a new file.
    Oct 01 2007
    Location, Location, Location
    Nice numbers!!
    I am curious to know how the car still feels with all the mods though. I heard that stage II is much more aggresive than a simple chip. I am looking at really modding my car like you have done (minus the tp), but i don't want it to feel...well..not like an audi (if that makes sense). I mean i still want it to be comfortable and drivable, but also be able to put out the power when i need it. So any comments you could offer on how it feels with the new software, exhuast and fuel pump would be appreciated.
    Thanks
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    way to represent the tips, nice job
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by masteroc View Post
    Nice numbers!!
    Thanks
    besides the car being loud b/c of the testpipe the car drives like a dream. it has not changed in driveability. love the mods. hope that helps.
    Veteran Member Four Rings dreamcar=rs4's Avatar
    Nov 04 2007
    A4 2.0T
    NorCal
    Yea I wouldnt have the guts to try that lol
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    So is it fact that the tip tranny in the A4 is the same used in the A8?
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    nice numbers, too bad we live so far away, we could have dont best of three at the strip. In Jan. I should have my turbo upgrade. P.S. Try launching at 3500, it works best.
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    4.9?? Can that be right? Damn, that's not far off an e46 m3's time. I've seen the m3 in various mags from 4.6-4.8 or so. Wow, I'm pretty stunned by that time, honestly.
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Well he does have every performance upgrade available
    Nov 04 2007
    A4 2.0T
    NorCal
    how much faster would manual be?
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Thanks for sharing this great info. As for 12.5 1/4 mile.....optimistic as usual.
    | APR KO4 | APR TP | APR FUEL PUMP | CARBONIO | AWE CBE | S4 DOORBLADES | BBS Ch | TINT | KW V1 | BSH PCV STAGE II | HOTCHKIS F/R SWAYS |
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    honestly, a manual would prob be slower because it is much harder to launch
    no way to get that much boost that early in the game
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    damn, 4.9? good shit - thanks for numbers
    man.. i'd be happy with 5.9
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    0-60 5.1
    0-60 5.3
    0-60 4.9.
    patrida alitheia re...?
    Wraios...
    (des kai to thema mou evala iliko)
    Keep up the good work there
    Rear Valence+Trunk Air Lip+Mirror Housings+WindowTrim CF'ed, Debadged Trunk, Front+Rear Red Tie Hooks, Engine Cover Removed, Painted WasherFluid+Coolant caps, Toyo Proxes Racing Semislick R888 225.40 (for now), OZ Ultraleggera 8x18 ET45 Black, 76mm Custom Cat-Back Exhaust, OEM BlackMask w/ black Audi Badge, Sparco 33mm Racing SteeringWheel, RUF Snap-off WheelHub, CF ShiftKnob, ColourMatched BrakeCalipers, APex-I TurboTimer black, Custom BilsteinPSS Coils by Kirlagkitsis Greece, Tinted Tailights, GReddy Electronic Φ=60 Warning A/F, WaterTemp, OilPress, FuelPress
    Defi BFSeries (w/ link) Φ=60, Boost, EGT, OilTemp, + 1, Custom GaugePods by XM Greece, PIAA CityLights Super White and White, Sparco CF Pedals, Simoni Racing SteeringWheel CronoMeter, Sachs Organic Racing Clutch Kit, Custom Decals, Alcantara Shift Boot, CAI, Forge 007 DV, Black HeadLights w/ Clear Corner Mod, Removed ArmRest
    Check it here
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by nsmith12 View Post
    true, but the fact that it's on the stock turbo is impressive to me. I just didn't know the car was capable of a sub 5 second 0-60 time. This is making me re-think my possible plans to get an e46 m3 in the (hopefully) near future.
    If I could get into an 06 a4 and hook it up like he did and get those results, it might be the way to go. With that kind of performance, I personally would not need a BT for the b7.
    <old school>
    Jan 01 2008
    Long Island NY
    IMO the A4 has really become a real well rounded car. Its definently faster than a stock S4 and i get over 30mpg on the highway.
    Oct 01 2007
    How did fuel economy change with the fsi fuel pump?
    Jan 01 2008
    Long Island NY
    i lost about 1-2mpg b/c of the fsi pump. around town i get about 24mpg but i am an aggressive driver.
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Pete, i love the post. I am really curious to see my 0-60 times. I think for some reason you are really optimistic because 4.9 0-60 is fast. Thats porsche territory!@! I need to have a few runs with you. I want to 0-60 mine as well. Also we need to set up the get togethers again! I have finally lowered my car and should have my cupra lip next week. I am getting married next saturday so lets try to do the gtg this thursday again! We should all meet up. I want to see your car with the intercooler. Sorry i never got back to you but i was really busy. Get back to me bud, lets do the gtg!!
    JD
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Jan 01 2008
    Long Island NY
    Im might be on vacation Thursday but i was thinking maybe doing a GTG Monday Night. What do you think?
    Apr 14 2008
    Oceanside, New York
    sure, that sounds good to me. Set it up...
    BMW M3 ZCP
    Oct 22 2005
    Reppin the Mitten.
    What I am curious about is how did you brake boost your car up to 3000+ rpm? I for sure thought the b7's would be like the b6's where it will cut off your throttle at a lower RPM. But def props to that time, that is really impressive for such a heavy car and a miniscule engine/turbo.
    Jan 01 2008
    Long Island NY
    Sometimes the car cuts the throttle thats why i have a hard time with consistency but it will let you do it once then if you put the car in drive a little and then try again it will do it again. it never lets you powerbrake over 3000 3 times in a row though.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    Very great numbers and informative for me.. Good job Auditude! Maybe I should finally attend a meet and see your monster in person.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
